WVC2300 Motion Detection Threshold
Answered Question
Feb 13th, 2012
Does a '-'  (minus) in the Threshold bar indicate that it is more sensitive, or does it indicate that it is less sensitive?
You think Cisco would have mentioned that in the Online Help.
Correct Answer by Eric Moyers about 5 years 2 months ago
Hello Sir,
This adjustment always makes me have to stop and think. If I remember correctly it is opposite of the way it looks on the settings. Closer to the "-"means more sensitive or the "less" it takes to activate the motion. Of course then the "+" meas=ns the less sensitive or the "more" it takes to activate the motion.
Hope this helps
Eric Moyers
Overall Rating: 5 (1 ratings)
Correct Answer
Eric Moyers Thu, 02/16/2012 - 07:10
  • Silver, 250 points or more
Hello Sir,
Hope this helps
Eric Moyers
clifford.gormley Thu, 02/16/2012 - 10:37
Thanks Eric,
That is what I think too.
I guess you may want to decrease the sensitivity for Motion Detector Windows where shadows (the sun movement causes shadow changes, tree movement shadows,) etc. are caused.
I have found that flat surfaces can be real sensitive to pick up shadows as motion, so I have moved my Motion Detection Windows away from walls, doors, etc. that have predominately flat surfaces.
Related Content
