IP directed-broadcast extended ACL
Answered Question
Feb 13th, 2012
Hi all,
I'm quite new to ACL's so fogive any errors.
I am currently trying to get Wake on LAN working in our enviroment to allow SCCM 2007 to wake computers. I have configured the ACL's to allow the packets across VLANS.
I followed the CISCO guide
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_example09186a008084b55c.shtml and it works, but i am concerned that i have left the security to open.
First i allowed the server in an ACL entry
permit udp host 192.168.99.x eq 7
then i allowed fowarding of WOL packets in broadcasts.
ip forward-protocol udp 7
Then on the VLAN interface i got a bit stuck. in the guide it says to input the ACL number after. however i use ACL names and i cannot add the name.
ip directed-broadcast ACLNumber
It WORKS great if i simply don't put the ACL number, but i fear that this is to "Open".
Any advice greatly appreciated!
Matt
Correct Answer by phiharri about 5 years 4 days ago
Hey Matt,
Per the command reference, only numbered ACLs can be given as an argument to the 'ip directed-broadcast' command, so you'll need to use config like:
access-list 101 permit udp host 192.168.1.x any eq 7
ip directed-broadcast 101
I didn't find any pending enhancements to allow named ACLs at this time.
Cheers,
/Phil
Overall Rating: 5 (2 ratings)
Richard Burts Mon, 02/13/2012 - 11:11
Matt
It is certainly true that ip directed-broadcast with ACL is more secure than ip directed-broadcast with no ACL. The degree of risk is probably not high, but you are better off if you get the access list to work.
I am puzzled at the ACL that you are trying to use. Since it specifies udp and specifies eq 7 it looks like it would be an extended access list. But since it only lists one IP address it looks like a standard access list and not extended access list. Perhaps you can supply more detail about the access list?
If you are trying to add the ACL for directed-broadcast and it is not accepting names of access lists it may be that the command requires that the ACL be a numbered list rather than a named list. I am not clear about that requirement, but it sounds that way from your description, and I know that the times that I have configured WOL I have used numbered access lists and they have worked fine.
Rick
phiharri Mon, 02/13/2012 - 11:32
As Rick mentioned, 'ip directed-broadcast' typically only takes a numbered (not named) access-list. It would help to know the specific platform and software release in use to confirm that!
Cheers,
/Phil
matt_isda_bomb Tue, 02/14/2012 - 01:02
Hi guys,
Thanks for getting back to me so fast.
The ACL is an extended list, my apologies the ACL entry i put in is below slight typo.
permit udp host 192.168.99.x any eq 7
Below is a Sh Ver
IOS (tm) s72033_rp Software (s72033_rp-IPSERVICESK9-M), Version 12.2(18)SXF17a,        RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by cisco Systems, Inc.
Compiled Tue 02-Mar-10 02:55 by tinhuang
Image text-base: 0x40101040, data-base: 0x42DD9910
ROM: System Bootstrap, Version 12.2(17r)S2, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-IPSERVICESK9-M), Version 12.2(18)SXF17a,        RELEASE SOFTWARE (fc1)
a-svr-6509-1 uptime is 1 year, 6 weeks, 3 days, 21 hours, 8 minutes
Time since a-svr-6509-1 switched to active is 1 year, 6 weeks, 3 days, 21 hours,        7 minutes
System returned to ROM by s/w reset at 09:02:07 GMT Thu Dec 30 2010 (SP by power        -on)
System restarted at 11:45:23 GMT Thu Dec 30 2010
System image file is "sup-bootflash:s72033-ipservicesk9-mz.122-18.SXF17a.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6509 (R7000) processor (revision 3.3) with 458720K/65536K bytes of memory.
Processor board ID SAL1023R106
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from power-on
SuperLAT software (copyright 1990 by Meridian Technology Corp).
X.25 software, Version 3.0.0.
Bridging software.
TN3270 Emulation software.
30 Virtual Ethernet/IEEE 802.3 interfaces
240 FastEthernet/IEEE 802.3 interfaces
58 Gigabit Ethernet/IEEE 802.3 interfaces
4 Ten Gigabit Ethernet/IEEE 802.3 interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Matt
Correct Answer
phiharri Tue, 02/14/2012 - 01:40
Hey Matt,
Cheers,
/Phil
matt_isda_bomb Tue, 02/14/2012 - 06:05
Hi Phil,
So is that basically setting up a standard ACL simply for the purpose of of securing the WOL ip directed-broadcast?
Cheers
Matt
phiharri Tue, 02/14/2012 - 06:51
Exactly Matt. To be precise it would be an IP extended access-list (numbers 101-199) to allow specifying the UDP port.
Cheers,
/Phil
Richard Burts Tue, 02/14/2012 - 10:58
Matt
I do not want to be overly picky. But I want to respond to something in your post to be sure that we are clear. You said:
There are two aspects of the ACL that we need to be careful about - is it a standard ACL or an extended ACL and is it a named ACL or a numbered ACL.
To control the directed broadcast that you are doing for WOL it needs to be an extended access list (not standard) and it needs to be numbered ACL (not named).
Rick
matt_isda_bomb Wed, 02/15/2012 - 00:55
Hi Rick,
Yes i have created a numbered extended access control list.
Thanks for clarifying,
Matt
Related Content
