Warning message
Deploying CUCM 8.x on MCS7835 I2 platform
Feb 13th, 2012
Hello:
My Company is in discussion of deploying an early version of CUCM 8.x from 6.x. We are currently using the 7835 I2 platform which is supported on the 8.x platform; however, the product will be end of support in May 2014. Is anyone aware of 8.x issues due to 7835 platform?  I know that UCS is the preferred platform; however, we may want to leverage our hardware until the end of support. Any information that you can provide will be helpful.
Thanks!
Chris Deren Mon, 02/13/2012 - 14:37
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Supported MCS servers are fine with latest versions of CUCM as long as you meet RAM and HDD requirements, which you may want to confirm.
HTH,
Chris
Gajanan Pande Tue, 02/14/2012 - 01:01
  • Cisco Employee,
In addition to Chris' point, if customer wants to continue with IBM branded MCS servers, there is nothing to worry because Cisco has not stopped rebranding/resaling IBM made servers under their MCS portfolio as they did for HP or eventually will do completely. So if any hardware goes end of support, you would very much have the replacement hardware available from IBM & supported by Cisco.
GP.
Pls rate helpful posts !!
