SSH not working from internet (Cisco 1941 router)
Answered Question
Feb 13th, 2012
I have a Cisco 1941 router configured using Cisco Configuration Professional... SSH management works from the LAN IP 10.0.1.254 and 10.0.2.254
Also, SSH management works from the LAN using the external domain name which resolves to the public IP address.
The problem i have is if I try SSH from the internet to the public IP.. nothing happens.
If anyone has any pointers on where/how to troubleshoot this, that would be appreaceted.
Also, I need some help setting up VNC passthough to a LAN workstation.
cisco1941#show config
Using 18498 out of 262136 bytes
! Last configuration change at 13:57:49 PCTime Tue Feb 14 2012 by admin
! NVRAM config last updated at 13:57:49 PCTime Tue Feb 14 2012 by admin
version 15.1
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname cisco1941
boot-start-marker
boot system flash0:/c1900-universalk9-mz.SPA.151-3.T1.bin
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200
logging console critical
enable secret 5 xxx
enable password 7 xxx
aaa new-model
aaa authentication login default local
aaa authentication login ciscocp_vpn_xauth_ml_1 local
aaa authorization exec default local
aaa session-id common
clock timezone PCTime 10 0
clock summer-time PCTime date Mar 30 2003 3:00 Oct 26 2003 2:00
no ipv6 cef
no ip source-route
ip cef
ip multicast-routing
no ip dhcp conflict logging
ip dhcp excluded-address 192.168.1.254
ip dhcp excluded-address 10.0.2.1 10.0.2.20
ip dhcp excluded-address 10.0.1.1 10.0.1.20
ip dhcp excluded-address 10.0.1.254
ip dhcp excluded-address 10.0.2.254
ip dhcp excluded-address 10.0.100.1 10.0.100.19
ip dhcp excluded-address 10.0.100.51 10.0.100.254
ip dhcp pool mydhcp
   import all
   network 192.168.0.0 255.255.255.0
   update dns
   default-router 192.168.0.254
   dns-server 61.9.195.193 61.9.194.49
   domain-name alliedfusion.local
ip dhcp pool WLAN-pool1
   import all
   network 10.0.2.0 255.255.255.0
   default-router 10.0.2.254
ip dhcp pool LAN-pool1
   import all
   network 10.0.1.0 255.255.255.0
   default-router 10.0.1.254
ip dhcp pool Cisco1142AP
   host 10.0.2.1 255.255.255.0
   client-name Cisco1142AP
ip dhcp pool ccp-pool1
   network 10.0.100.0 255.255.255.0
   domain-name dmz.local
   default-router 10.0.100.254
no ip bootp server
ip domain name alliedfusion.local
ip name-server 61.9.195.193
ip name-server 61.9.194.49
ip port-map user-vnc port tcp 5900 list 4 description vnc-portmap
ip ddns update method ccp_ddns1
HTTP
  add http://xxx:@www.dyns.cx/postscript.php?username=username=cxxx&passwort=<h>&ip=<a>
no ip igmp snooping
parameter-map type protocol-info msn-servers
server name messenger.hotmail.com
server name gateway.messenger.hotmail.com
server name webmessenger.msn.com
parameter-map type protocol-info yahoo-servers
server name scs.msg.yahoo.com
server name scsa.msg.yahoo.com
server name scsb.msg.yahoo.com
server name scsc.msg.yahoo.com
server name scsd.msg.yahoo.com
server name cs16.msg.dcn.yahoo.com
server name cs19.msg.dcn.yahoo.com
server name cs42.msg.dcn.yahoo.com
server name cs53.msg.dcn.yahoo.com
server name cs54.msg.dcn.yahoo.com
server name ads1.vip.scd.yahoo.com
server name radio1.launch.vip.dal.yahoo.com
server name in1.msg.vip.re2.yahoo.com
server name data1.my.vip.sc5.yahoo.com
server name address1.pim.vip.mud.yahoo.com
server name edit.messenger.yahoo.com
server name messenger.yahoo.com
server name http.pager.yahoo.com
server name privacy.yahoo.com
server name csa.yahoo.com
server name csb.yahoo.com
server name csc.yahoo.com
parameter-map type protocol-info aol-servers
server name login.oscar.aol.com
server name toc.oscar.aol.com
server name oam-d09a.blue.aol.com
crypto pki trustpoint TP-self-signed-640030031
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-640030031
revocation-check none
rsakeypair TP-self-signed-640030031
crypto pki trustpoint tti
revocation-check crl
crypto pki certificate chain TP-self-signed-640030031
certificate self-signed 01 nvram:IOS-Self-Sig#3.cer
crypto pki certificate chain tti
license udi pid CISCO1941/K9 sn FHK1421759M
license boot module c1900 technology-package securityk9
license boot module c1900 technology-package datak9
license agent notify http://10.0.1.6:1941/clm/servlet/HttpListenServlet dummy dummy 1.0
username admin privilege 15 secret 5 xxx
redundancy
ip tcp synwait-time 10
no ip ftp passive
ip ssh version 2
class-map type inspect match-any SDM_BOOTPC
match access-group name SDM_BOOTPC
class-map type inspect match-any ssh-in-out
match protocol ssh
class-map type inspect imap match-any ccp-app-imap
match  invalid-command
class-map type inspect match-any ccp-cls-protocol-p2p
match protocol edonkey signature
match protocol gnutella signature
match protocol kazaa2 signature
match protocol fasttrack signature
match protocol bittorrent signature
class-map type inspect match-any SDM_DHCP_CLIENT_PT
match class-map SDM_BOOTPC
class-map type inspect match-any ccp-skinny-inspect
match protocol skinny
class-map type inspect match-any sdm-cls-bootps
match protocol bootps
class-map type inspect match-any ccp-cls-insp-traffic
match protocol dns
match protocol ftp
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
match protocol netshow
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
class-map type inspect match-all ccp-insp-traffic
match class-map ccp-cls-insp-traffic
class-map type inspect gnutella match-any ccp-app-gnutella
match  file-transfer
class-map type inspect ymsgr match-any ccp-app-yahoo-otherservices
match  service any
class-map type inspect msnmsgr match-any ccp-app-msn-otherservices
match  service any
class-map type inspect match-any ccp-h323nxg-inspect
match protocol h323-nxg
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
class-map type inspect match-any ccp-cls-protocol-im
match protocol ymsgr yahoo-servers
match protocol msnmsgr msn-servers
match protocol aol aol-servers
class-map type inspect aol match-any ccp-app-aol-otherservices
match  service any
class-map type inspect match-all ccp-protocol-pop3
match protocol pop3
class-map type inspect match-all ccp-cls-ccp-inspect-1
match class-map ssh-in-out
match access-group name ssh-in-out
class-map type inspect match-any ccp-h225ras-inspect
match protocol h225ras
class-map type inspect match-any ccp-h323annexe-inspect
match protocol h323-annexe
class-map type inspect match-any user-vnc
match protocol user-vnc
class-map type inspect match-any SDM_SSH
match access-group name SDM_SSH
class-map type inspect pop3 match-any ccp-app-pop3
class-map type inspect match-any SDM_HTTPS
match access-group name SDM_HTTPS
class-map type inspect kazaa2 match-any ccp-app-kazaa2
match  file-transfer
class-map type inspect match-all ccp-protocol-p2p
match class-map ccp-cls-protocol-p2p
class-map type inspect match-any SDM_SHELL
match access-group name SDM_SHELL
class-map type inspect match-any ccp-h323-inspect
match protocol h323
match  service text-chat
class-map type inspect match-all ccp-protocol-im
match class-map ccp-cls-protocol-im
class-map type inspect match-all ccp-invalid-src
match access-group 100
class-map type inspect match-all ccp-icmp-access
match class-map ccp-cls-icmp-access
class-map type inspect http match-any ccp-app-httpmethods
match  request method bcopy
match  request method bdelete
match  request method bmove
match  request method bpropfind
match  request method bproppatch
match  request method connect
match  request method copy
match  request method delete
match  request method edit
match  request method getattribute
match  request method getattributenames
match  request method getproperties
match  request method index
match  request method lock
match  request method mkcol
match  request method mkdir
match  request method move
match  request method notify
match  request method options
match  request method poll
match  request method propfind
match  request method proppatch
match  request method put
match  request method revadd
match  request method revlabel
match  request method revlog
match  request method revnum
match  request method save
match  request method search
match  request method setattribute
match  request method startrev
match  request method stoprev
match  request method subscribe
match  request method trace
match  request method unedit
match  request method unlock
match  request method unsubscribe
class-map type inspect match-any ccp-dmz-protocols
match protocol http
class-map type inspect edonkey match-any ccp-app-edonkey
match  file-transfer
match  text-chat
match  search-file-name
class-map type inspect match-any ccp-sip-inspect
match protocol sip
class-map type inspect http match-any ccp-http-blockparam
match  request port-misuse im
match  request port-misuse p2p
match  req-resp protocol-violation
class-map type inspect match-all ccp-dmz-traffic
match access-group name dmz-traffic
match class-map ccp-dmz-protocols
class-map type inspect edonkey match-any ccp-app-edonkeydownload
match  file-transfer
class-map type inspect match-all ccp-protocol-imap
match protocol imap
class-map type inspect edonkey match-any ccp-app-edonkeychat
match  text-chat
class-map type inspect http match-any ccp-http-allowparam
match  request port-misuse tunneling
class-map type inspect fasttrack match-any ccp-app-fasttrack
match  file-transfer
class-map type inspect match-all ccp-protocol-http
match protocol http
policy-map type inspect ccp-permit-icmpreply
class type inspect sdm-cls-bootps
  pass
class type inspect ccp-icmp-access
  inspect
class class-default
  pass
policy-map type inspect p2p ccp-action-app-p2p
class type inspect edonkey ccp-app-edonkeychat
  log
  allow
class type inspect edonkey ccp-app-edonkeydownload
  log
  allow
class type inspect fasttrack ccp-app-fasttrack
  log
  allow
class type inspect gnutella ccp-app-gnutella
  log
  allow
class type inspect kazaa2 ccp-app-kazaa2
  log
  allow
policy-map type inspect user-vnc-allow
class type inspect user-vnc
  pass
policy-map type inspect im ccp-action-app-im
class type inspect aol ccp-app-aol
  log
  allow
class type inspect msnmsgr ccp-app-msn
  log
  allow
class type inspect ymsgr ccp-app-yahoo
  log
  allow
class type inspect aol ccp-app-aol-otherservices
  log
  reset
class type inspect msnmsgr ccp-app-msn-otherservices
  log
  reset
class type inspect ymsgr ccp-app-yahoo-otherservices
  log
  reset
policy-map type inspect http ccp-action-app-http
class type inspect http ccp-http-blockparam
  log
  allow
class type inspect http ccp-app-httpmethods
  log
  reset
class type inspect http ccp-http-allowparam
  log
  allow
policy-map type inspect imap ccp-action-imap
class type inspect imap ccp-app-imap
  log
policy-map type inspect pop3 ccp-action-pop3
class type inspect pop3 ccp-app-pop3
  log
policy-map type inspect ccp-inspect
class type inspect ccp-invalid-src
  drop log
class type inspect ccp-protocol-http
  inspect
  service-policy http ccp-action-app-http
class type inspect ccp-protocol-imap
  inspect
  service-policy imap ccp-action-imap
class type inspect ccp-protocol-pop3
  inspect
  service-policy pop3 ccp-action-pop3
class type inspect ccp-protocol-p2p
  inspect
  service-policy p2p ccp-action-app-p2p
  inspect
  service-policy im ccp-action-app-im
class type inspect ccp-insp-traffic
  inspect
class type inspect ccp-sip-inspect
  pass
class type inspect ccp-h323-inspect
  inspect
class type inspect ccp-h323annexe-inspect
  inspect
class type inspect ccp-h225ras-inspect
  inspect
class type inspect ccp-h323nxg-inspect
  inspect
class type inspect ccp-skinny-inspect
  inspect
class class-default
  drop
class type inspect SDM_DHCP_CLIENT_PT
  pass
class class-default
  drop
policy-map type inspect ccp-permit-dmzservice
class type inspect ccp-dmz-traffic
  inspect
class class-default
  drop
zone security dmz-zone
zone security out-zone
zone security in-zone
zone-pair security ccp-zp-self-out source self destination out-zone
service-policy type inspect ccp-permit-icmpreply
zone-pair security ccp-zp-in-dmz source in-zone destination dmz-zone
service-policy type inspect ccp-permit-dmzservice
zone-pair security ccp-zp-in-out source in-zone destination out-zone
service-policy type inspect ccp-inspect
zone-pair security ccp-zp-out-dmz source out-zone destination dmz-zone
zone-pair security ccp-zp-out-self source out-zone destination self
interface Null0
no ip unreachables
interface GigabitEthernet0/0
description External interface$ETH-WAN$$FW_OUTSIDE$
ip dhcp client hostname Cisco1941
ip dhcp client update dns server none
ip ddns update ccp_ddns1
ip address dhcp client-id GigabitEthernet0/0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
ip virtual-reassembly in
zone-member security out-zone
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
description internal interface$ES_LAN$$ETH-LAN$$FW_INSIDE$
ip address 192.168.0.254 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
zone-member security in-zone
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1/0
description Cisco1142 AP
switchport trunk native vlan 50
switchport mode trunk
vlan-id dot1q 50
  exit-vlan-config
interface GigabitEthernet0/1/1
switchport access vlan 10
interface GigabitEthernet0/1/2
interface GigabitEthernet0/1/3
switchport access vlan 100
interface GigabitEthernet0/1/4
description NAS#2 WLAN
switchport access vlan 50
duplex full
speed 1000
power inline never
vlan-id dot1q 50
  exit-vlan-config
interface GigabitEthernet0/1/5
description NAS#1 LAN
duplex full
speed 1000
power inline never
spanning-tree portfast
interface GigabitEthernet0/1/6
description NetCom Powerline
power inline never
interface GigabitEthernet0/1/7
description Lounge and TV
power inline never
interface Virtual-Template1
description $FW_INSIDE$
ip unnumbered GigabitEthernet0/0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
interface Vlan1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
interface Vlan10
ip address 10.0.1.254 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
interface Vlan50
ip address 10.0.2.254 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
interface Vlan100
description $FW_DMZ$
ip address 10.0.100.254 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
zone-member security dmz-zone
router rip
passive-interface GigabitEthernet0/1
passive-interface Vlan1
passive-interface Vlan10
passive-interface Vlan50
network 10.0.0.0
network 192.168.0.0
no auto-summary
ip local pool SSLVPN_POOL1 172.16.1.1 172.16.1.50
ip forward-protocol nd
ip http server
ip http access-class 2
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip access-list extended Router-Access
permit tcp any any eq telnet
permit tcp any any eq 22
permit tcp any any eq 443
ip access-list extended SDM_BOOTPC
remark CCP_ACL Category=0
permit udp any any eq bootpc
ip access-list extended SDM_HTTPS
remark CCP_ACL Category=1
ip access-list extended SDM_SHELL
permit tcp any any eq cmd
ip access-list extended SDM_SSH
ip access-list extended dmz-traffic
permit ip any host 10.0.100.1
permit ip any host 10.0.100.2
ip access-list extended ssh-in-out
remark CCP_ACL Category=128
permit ip any any
logging esm config
logging trap debugging
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 10.0.1.0 0.0.0.255
access-list 1 permit 10.0.2.0 0.0.0.255
access-list 2 remark HTTP Access-class list
access-list 2 remark CCP_ACL Category=1
access-list 2 permit 10.0.2.0 0.0.0.255
access-list 2 permit 10.0.1.0 0.0.0.255
access-list 2 permit 192.168.0.0 0.0.0.255
access-list 2 deny   any
access-list 3 remark CCP_ACL Category=1
access-list 3 permit 10.0.2.21
access-list 4 remark CCP_ACL Category=1
access-list 4 permit 10.0.2.21
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
no cdp run
control-plane
banner exec ^C
Welcome AlliedFusion (config exec)
^C
banner login ^CWelcome AlliedFusion (1941 login)
^C
banner motd ^C
Welcome AlliedFusion (config line)
^C
line con 0
transport output telnet
line aux 0
line vty 0 4
access-class 23 in
password 7 113E1C09141D06095D7C72
transport input telnet ssh
transport output telnet ssh
line vty 5 15
access-class 23 in
scheduler allocate 20000 1000
ntp source GigabitEthernet0/0
ntp master
ntp update-calendar
end
Correct Answer by cadet alain about 5 years 6 months ago
can you add this command to confirm that ZBF policy from out to self is dropping the ssh reply  packets from the router :
ip inspect log drop-pkt
This is surely the culprit:
  pass
class class-default
  drop
if this is the case then you can do this:
class-map type inspect ssh-reply
match protocol ssh
  pass
class type inspect ssh-reply
pass
class class-default
  drop
Regards.
Alain
Overall Rating: 5 (1 ratings)
Correct Answer
cadet alain Tue, 02/14/2012 - 00:16
  • Purple, 4500 points or more
  pass
class class-default
  drop
match protocol ssh
  pass
pass
class class-default
  drop
Regards.
Alain
charlesjudd Tue, 02/14/2012 - 01:01
Thanks!
you're feedback solved the problem.
Great forum, and CCP is great for techies from other spheres.  Kudos Cisco.
Related Content
