Presence Instant Message error.
Feb 14th, 2012
  • Bronze, 100 points or more
I've set up a Presence server (8.5.1) and managed to stumble my way into getting everything working and synched with LDAP/CUCM.
Unfortunately, I'm getting the following error when attempting to message: Failed to send instant message to remote participant. [2100]
The message actually does go thru to the recipient with no problem. System Diagnostics show no issues.
Any Ideas?
Gareth
Christos Georgiadis Fri, 02/17/2012 - 12:23
  • Silver, 250 points or more
Hey Gareth,
Can you check the release notes for defect CSCtj54308 ? I think it applies in your case
HTH,
Christos
garethpeart Mon, 02/20/2012 - 06:16
Christos,
The indicates an upgrade from 7.x to 8.x. Sadly, this is a fresh install. But I have narrowed down the issue to a single user.... me. All other test users can IM between themselves with no errors.
Gareth
Christos Georgiadis Mon, 02/20/2012 - 10:46
Hi Gareth,
Can you try the following commands from cli ?
Admin: run pe sql ttreg select * from contact where fk_aorpkid like '%msmith%';
Admin: run pe sql ttreg select * from registration where fk_aorpkid like '%msmith%';
Admin: run pe sql ttreg select * from aor where aorpkid like '%msmith%';
where userid is msmith. Replace the userid with your userid
Are there any results ? Or do you get 0 rows found ?
HTH,
Christos
garethpeart Thu, 02/23/2012 - 07:38
Christos,
I had tried that before and did it again just now. Each command returns "0 rows found"
Gareth
