Warning message
Customized Softkeys
Feb 14th, 2012
Is there a way to create a new customized softkey to use on a template? I have set my direct call park retrival code as a line speed dial but would like to have it show as a softkey instead to save some room.
Anyway to do this in CUCM 8.5?
Chris Deren Tue, 02/14/2012 - 10:52
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Unfortunately, there is no way of adding softkey options outside of what you see under the layout.
HTH,
Chris
