Warning message
This is frustrating... trying to import CISCO-ENTITY-SENSOR-MIB
Answered Question
Feb 14th, 2012
  • Gold, 750 points or more
Well, really trying to import CISCO-ENTITY-SENSOR-EXT-MIB in order to process traps from ASA with "snmp-server enable traps entity power-supply-failure" configured. Figures that CISCO-ENTITY-SENSOR-MIB is a prerequisite. After painstakingly loading up the MIB dependencies listed at http://tools.cisco.com/Support/SNMP/do/BrowseMIB.do?local=en&step=2&mibName=CISCO-ENTITY-SENSOR-MIB, it fails at the last juncture with
CISCO-ENTITY-SENSOR-MIB itself:
snmpttconvertmib --in=CISCO-ENTITY-SENSOR-MIB.my --out=/etc/snmp/snmptt.conf.cisco --debug
*****  Processing MIB file *****
snmptranslate version: NET-SNMP version: 5.3.1
severity: Normal
File to load is:        ./CISCO-ENTITY-SENSOR-MIB.my
File to APPEND TO:      /etc/snmp/snmptt.conf.cisco
MIBS environment var:   ./CISCO-ENTITY-SENSOR-MIB.my
mib name: CISCO-ENTITY-SENSOR-MIB
Processing MIB:         CISCO-ENTITY-SENSOR-MIB
skipping a TRAP-TYPE / NOTIFICATION-TYPE line - probably an import line.
Line: 631
NOTIFICATION-TYPE: entSensorThresholdNotification
Variables: entSensorThresholdValue entSensorValue
Enterprise: entitySensorMIBNotifications
Looking up via snmptranslate: CISCO-ENTITY-SENSOR-MIB::entSensorThresholdNotification
No log handling enabled - turning on stderr logging
Cannot find module (ENTITY-MIB): At line 27 in ./CISCO-ENTITY-SENSOR-MIB.my
Cannot find module (CISCO-TC): At line 29 in ./CISCO-ENTITY-SENSOR-MIB.my
Cannot find module (CISCO-SMI): At line 31 in ./CISCO-ENTITY-SENSOR-MIB.my
Did not find 'entPhysicalIndex' in module #-1 (./CISCO-ENTITY-SENSOR-MIB.my)
Did not find 'EntPhysicalIndexOrZero' in module #-1 (./CISCO-ENTITY-SENSOR-MIB.my)
Did not find 'ciscoMgmt' in module #-1 (./CISCO-ENTITY-SENSOR-MIB.my)
Unlinked OID in CISCO-ENTITY-SENSOR-MIB: ciscoEntitySensorMIB ::= { ciscoMgmt 91 }
Undefined identifier: ciscoMgmt near line 33 of ./CISCO-ENTITY-SENSOR-MIB.my
Cannot adopt OID in CISCO-ENTITY-SENSOR-MIB: entitySensorMIBConformance ::= { ciscoEntitySensorMIB 3 }
Cannot adopt OID in CISCO-ENTITY-SENSOR-MIB: entitySensorMIBNotificationPrefix ::= { ciscoEntitySensorMIB 2 }
Cannot adopt OID in CISCO-ENTITY-SENSOR-MIB: entitySensorMIBObjects ::= { ciscoEntitySensorMIB 1 }
Cannot adopt OID in CISCO-ENTITY-SENSOR-MIB: entitySensorMIBNotifications ::= { entitySensorMIBNotificationPrefix 0 }
Cannot adopt OID in CISCO-ENTITY-SENSOR-MIB: entSensorValueEntry ::= { entSensorValueTable 1 }
Cannot adopt OID in CISCO-ENTITY-SENSOR-MIB: entitySensorNotifCtrlGlobalGroup ::= { entitySensorMIBGroups 5 }
Cannot adopt OID in CISCO-ENTITY-SENSOR-MIB: entitySensorValueGroupSup1 ::= { entitySensorMIBGroups 4 }
Cannot adopt OID in CISCO-ENTITY-SENSOR-MIB: entitySensorThresholdNotificationGroup ::= { entitySensorMIBGroups 3 }
Cannot adopt OID in CISCO-ENTITY-SENSOR-MIB: entitySensorThresholdGroup ::= { entitySensorMIBGroups 2 }
Cannot adopt OID in CISCO-ENTITY-SENSOR-MIB: entitySensorValueGroup ::= { entitySensorMIBGroups 1 }
Cannot adopt OID in CISCO-ENTITY-SENSOR-MIB: entSensorThresholdTable ::= { entSensorThresholds 1 }
Cannot adopt OID in CISCO-ENTITY-SENSOR-MIB: entSensorMeasuredEntity ::= { entSensorValueEntry 8 }
Cannot adopt OID in CISCO-ENTITY-SENSOR-MIB: entSensorValueUpdateRate ::= { entSensorValueEntry 7 }
Cannot adopt OID in CISCO-ENTITY-SENSOR-MIB: entSensorValueTimeStamp ::= { entSensorValueEntry 6 }
Cannot adopt OID in CISCO-ENTITY-SENSOR-MIB: entSensorStatus ::= { entSensorValueEntry 5 }
Cannot adopt OID in CISCO-ENTITY-SENSOR-MIB: entSensorValue ::= { entSensorValueEntry 4 }
Cannot adopt OID in CISCO-ENTITY-SENSOR-MIB: entSensorPrecision ::= { entSensorValueEntry 3 }
Cannot adopt OID in CISCO-ENTITY-SENSOR-MIB: entSensorScale ::= { entSensorValueEntry 2 }
Cannot adopt OID in CISCO-ENTITY-SENSOR-MIB: entSensorType ::= { entSensorValueEntry 1 }
Cannot adopt OID in CISCO-ENTITY-SENSOR-MIB: entSensorThresholdEntry ::= { entSensorThresholdTable 1 }
Cannot adopt OID in CISCO-ENTITY-SENSOR-MIB: entSensorThreshNotifGlobalEnable ::= { entSensorGlobalObjects 1 }
Cannot adopt OID in CISCO-ENTITY-SENSOR-MIB: ciscoEntitySensorMIB ::= { ciscoMgmt 91 }
Cannot adopt OID in CISCO-ENTITY-SENSOR-MIB: entSensorGlobalObjects ::= { entitySensorMIBObjects 3 }
Cannot adopt OID in CISCO-ENTITY-SENSOR-MIB: entSensorThresholds ::= { entitySensorMIBObjects 2 }
Cannot adopt OID in CISCO-ENTITY-SENSOR-MIB: entSensorValues ::= { entitySensorMIBObjects 1 }
Cannot adopt OID in CISCO-ENTITY-SENSOR-MIB: entSensorThresholdNotificationEnable ::= { entSensorThresholdEntry 6 }
Cannot adopt OID in CISCO-ENTITY-SENSOR-MIB: entSensorThresholdEvaluation ::= { entSensorThresholdEntry 5 }
Cannot adopt OID in CISCO-ENTITY-SENSOR-MIB: entSensorThresholdValue ::= { entSensorThresholdEntry 4 }
Cannot adopt OID in CISCO-ENTITY-SENSOR-MIB: entSensorThresholdRelation ::= { entSensorThresholdEntry 3 }
Cannot adopt OID in CISCO-ENTITY-SENSOR-MIB: entSensorThresholdSeverity ::= { entSensorThresholdEntry 2 }
Cannot adopt OID in CISCO-ENTITY-SENSOR-MIB: entSensorThresholdIndex ::= { entSensorThresholdEntry 1 }
Cannot adopt OID in CISCO-ENTITY-SENSOR-MIB: entSensorThresholdNotification ::= { entitySensorMIBNotifications 1 }
Cannot adopt OID in CISCO-ENTITY-SENSOR-MIB: entSensorValueTable ::= { entSensorValues 1 }
Cannot adopt OID in CISCO-ENTITY-SENSOR-MIB: entitySensorMIBGroups ::= { entitySensorMIBConformance 2 }
Cannot adopt OID in CISCO-ENTITY-SENSOR-MIB: entitySensorMIBCompliances ::= { entitySensorMIBConformance 1 }
Cannot adopt OID in CISCO-ENTITY-SENSOR-MIB: entitySensorMIBComplianceV04 ::= { entitySensorMIBCompliances 4 }
Cannot adopt OID in CISCO-ENTITY-SENSOR-MIB: entitySensorMIBComplianceV03 ::= { entitySensorMIBCompliances 3 }
Cannot adopt OID in CISCO-ENTITY-SENSOR-MIB: entitySensorMIBComplianceV02 ::= { entitySensorMIBCompliances 2 }
Cannot adopt OID in CISCO-ENTITY-SENSOR-MIB: entitySensorMIBComplianceV01 ::= { entitySensorMIBCompliances 1 }
Unknown object identifier: CISCO-ENTITY-SENSOR-MIB::entSensorThresholdNotification
OID:
Done
Total translations:        1
Successful translations:   0
Failed translations:       1
Those three allegedly missing MIBs are right there in the same directory, and have been imported earlier (though some had no "translation"):
ls
CISCO-ENTITY-SENSOR-EXT-MIB.my  CISCO-TC.my     RFC-1212.my            SNMPv2-CONF.my  SNMPv2-TC-V1SMI.my
CISCO-ENTITY-SENSOR-MIB.my      ENTITY-MIB.my   RFC-1215.my            SNMPv2-SMI.my   v1
CISCO-SMI.my                    RFC1155-SMI.my  SNMP-FRAMEWORK-MIB.my  SNMPv2-TC.my
snmpttconvertmib --in=CISCO-SMI.my --out=/etc/snmp/snmptt.conf.cisco --debug
severity: Normal
File to load is:        ./CISCO-SMI.my
MIBS environment var:   ./CISCO-SMI.my
mib name: CISCO-SMI
Processing MIB:         CISCO-SMI
Done
Total translations:        0
Failed translations:       0
snmpttconvertmib --in=CISCO-TC.my --out=/etc/snmp/snmptt.conf.cisco --debug
severity: Normal
File to load is:        ./CISCO-TC.my
MIBS environment var:   ./CISCO-TC.my
mib name: CISCO-TC
Processing MIB:         CISCO-TC
Done
snmpttconvertmib --in=ENTITY-MIB.my --out=/etc/snmp/snmptt.conf.cisco --debug
severity: Normal
File to load is:        ./ENTITY-MIB.my
MIBS environment var:   ./ENTITY-MIB.my
mib name: ENTITY-MIB
Processing MIB:         ENTITY-MIB
Line: 1142
NOTIFICATION-TYPE: entConfigChange
Enterprise: entityMIBTrapPrefix
Looking up via snmptranslate: ENTITY-MIB::entConfigChange
OID: .1.3.6.1.2.1.47.2.0.1
Done
Successful translations:   1
What am I missing?
Correct Answer by Martin Ermel about 5 years 6 months ago
yjdabear, nice to hear again from you!
I found this, but I am not sure if this is really the cause of your problem...
snmpttconvertmib relies on snmptranslate; and snmptranslate looks up for mib files in
    $HOME/.snmp/mibs
    /usr/local/share/snmp/mibs
put the prerequisite mib files into one of these directories and try to re-run snmpttconvertmib;
Overall Rating: 5 (1 ratings)
Michel Hegeraat Wed, 02/15/2012 - 09:49
I've successfully tried to stay clear of this type of thing as much as I could so my response might be silly.
But one of the things I recall was that a 'somemib.my' file needed 'thatothermib', that was actually there in the directory as 'thatothermib.my', just like I downloaded it, but the mibcompiler was smart enough to look for 'thatothermib.mib'.
Not sure if is was referenced in the other mibfile with a specific extension of if it was the compiler trying to stop me.
Never understood how they managed to make something so simple so complicated.
Cheers,
Michel
Correct Answer
Martin Ermel Thu, 02/16/2012 - 01:27
  • Blue, 1500 points or more
    $HOME/.snmp/mibs
yjdabear Thu, 02/16/2012 - 11:40
You're the man, Martin! (Sie sind der Mann???)
Sticking the mibs in the top level of either ~/.snmp/mibs or /usr/share/snmp/mibs did the trick, but not /usr/local/share/snmp/mibs. I had them in a subdirectory under /usr/share/snmp/mibs, which apparently doesn't fly with snmpttconvertmib/snmptranslate. Le Sigh.
