Warning message
SSH Cisco 3750
Feb 14th, 2012
Is there a way how to enable the ssh connection in a cisco switch 3750 Series?
At the moment i was trying to configure the command transport input ssh but the switche didnt support.
Is this an IOS limitation?
My current version us
c3750-ipservices-mz.122-35.SE5/c3750-ipservices-mz.122-35.SE5.bin"
Its an stack about 9 switches.
Neeraj Arora Tue, 02/14/2012 - 12:28
  • Silver, 250 points or more
The IOS (c3750-ipservices-mz.122-35.SE5.bin) being used does not support any encryption, thats why you are not able to configure ssh on vty lines
You need to upgrade the IOS with a featureset which has k9 in it, for eg.:
c3750-ipservicesk9-mz.122-35.SE5.bin
c3750-advipservicesk9-mz.122-35.SE5.bin
If you have a valid CCO id then you can try and download the IOS from this link:
http://www.cisco.com/cisco/software/find.html?q=3750&task=default
Also go through the following document for more info on configuring SSH on routers and switches:
http://www.cisco.com/en/US/tech/tk583/tk617/technologies_tech_note09186a00800949e2.shtml
Hope it helps
Neeraj
