Network issue
Nick Sinyakov
Hi guys,
My network structure in on image.
There were no problems untill I've added another unmanaged swich Cisco SR2024. It's connected via 4 cables to managed switch Cisco 2960. There is config for these 4 ports:
interface Port-channel2
switchport mode trunk
interface GigabitEthernet0/41
description Netgear_SW_link1
switchport access vlan 10
switchport trunk native vlan 10
mls qos trust cos
channel-group 2 mode auto
interface GigabitEthernet0/42
description Netgear_SW_link2
mls qos trust cos
spanning-tree bpduguard enable
interface GigabitEthernet0/43
description Netgear_SW_link3
mls qos trust cos
interface GigabitEthernet0/44
description Netgear_SW_link4
mls qos trust cos
Also 2960 is DHCP!
So problems are:
- unable to get access to VMs VPN, AD (server connected to SR2024) from 192.168.10.7 (same VLAN)
- unable to get access to SMTP from Printer which connected to 2960
- VPN client unable to get IP from DHCP (errors 691,733,800)
What should I change to fix these issue? (Just a reminder, all these problems started with SR2024, but I have to use it - not enough ports on 2960)
2 Accepted Solutions
darren.g
Level 5
Level 5
Nick Sinyakov wrote:
Hi guys,
mls qos trust cos
mls qos trust cos
mls qos trust cos
mls qos trust cos
Also 2960 is DHCP!
So problems are:
The SR2024 supports neither etherchannel nor 802.1q trunking - so I'm not surprised it doesn't work!
As far as the SR2024 is concerned, all ports are in the same VLAN/Broadcast domain, and all are access ports - there's no tagging.
So your etherchannel won't work, and neither will trying to trunk multiple VLAN's to the SR2024.
If you *must* use it, then put ONE connecting port on the 2960 into access mode in ONE VLAN, and then all devices on the SR2024 will be in that VLAN. But there's no way you can have VLAN1/VLAN2 hanging off the SR2024. And you'll only have the bandwidth of one port linking the two devices together - trying to add another will result in the 2960 puttint ports into blocking mode.
Best solution - buy a better switch! Or modify your requirements to include only one VLAN
Cheers.
Thanks for clear answer. Also I have Netgear GS748TS which is smart switch and should be able to carry few VLANS via 1 port, but I didn't find the instruction how to setup "CISCO TRUNK through NETGEAR" and how use etherchannel between them.
This Netgear switch supports dot1q trunking, so you can make it work. it also supports 802.3ad, so you can probably use a port-channel to get more bandwidth between the switches - although instead of "mode auto", I'd suggest "mode active" because the Netgear only supports LACP, and this will force the Cisco to use LACP for the port-channel.
because the Netgear supports dot1q, you can also trunk - so carry VLAN 1 and VLAN 2 across the link, and assign ports in it to different VLAN's - but I have no idea how to set this up, as I've never used one of those.
Good luck.
8 Replies 8
Leo Laohoo
SR2024, I believe, is an un-managed switch.  I don't know it this will support etherchannel.
Yes, you right, it's unmanaged switch. I meant channel-group is setup only on 2960 site for connection redundance. So I can't create etherchannel between managed and un-managed switches?
You can create an etherchannel on a managed switch (if this feature is supported) but an un-managed switch doesn't "understand" and just might create an STP loop.
darren.g
Level 5
Level 5
Hi guys,
mls qos trust cos
mls qos trust cos
mls qos trust cos
mls qos trust cos
Also 2960 is DHCP!
So problems are:
Cheers.
If funding is an issue, try Cisco Refurbished.
Good luck.
Thanks for replies. I've raised this setup with Netgear support.
