Switching
Get 20% off switches when you combine Cisco solutions
Labels
CIAOUn cliente ci chiede quanto calore produce un interruttore 3650 per calcolare l'HVAC per il raffreddamento. Stiamo controllando la SCHEDA DATI ma le uniche informazioni a riguardo sono il flusso d'aria e la temperatura operativa.Qualcuno sa dove ...
umutsare by Level 1
  • 18 Views
  • 0 replies
Hi, I am working on a RFP where one of the specs says " the switch should support IEEE802.3ah ethernet link OAM and IEEE 802.1ag/ITU-T Y.1731" this is the only point which i am not able to find a reference in cisco documents, though we have a cisco 9...
Hi, I have a C2960L-SM and noticed that I can't connect over ssh anymore. I getssh_exchange_identification: Connection closed by remote host If I run show ip ssh it seems ssh is running:SSH Enabled - version 1.99 ... and so on What can I do? Especial...
tokon by Level 1
  • 7434 Views
  • 23 replies
Resolved! vmware nic teaming
Hi, if NIC are teamed on VMWARE  and set to "route based on the orginating virtual id" do i need to port-channel on the cisco switch ?
Guys I am trying to determine what the difference between "full poe" and "poe"I am replacing a few WS-C3560G-48PS-S switches at my clients and need to make sure I am providing them with the same PoE functionality that they currently have with the WS-...
a-belesimo by Level 1
  • 17349 Views
  • 8 replies
I think I already know the answer to this.Will an SFP-10G-SR work in the 4G model if the interface is set to 'speed 1000' ?It currently keeps err-disabling in the 9200, even with speed at 1000I have a 9200 connected to a CBS350 (which I am sure will ...
sw# show system resourcesLoad average:   1 minute: 0.33   5 minutes: 0.38   15 minutes: 0.31Processes   :   576 total, 1 runningCPU states  :   0.25% user,   1.00% kernel,   98.74% idle                CPU0 states  :   0.00% user,   0.00% kernel,   10...
