Warning message
Restrict phones in Device Pool
Feb 14th, 2012
Hello All,
We want to restrict phones that are connected to different device pools.
e.g.
If we have two buildings with seperate device pool for each. We want to restrict roaming between these two buildings based on device pool.
Thanks.
Overall Rating: 4 (2 ratings)
paolo bevilacqua Wed, 02/15/2012 - 04:20
  • Hall of Fame,
    Founding Member
You can configure MAC security/authenticaion in the switches and that will make so only devices you configure will connect at the place you want them to be.
Essam Nasir Wed, 02/15/2012 - 04:41
Well yes, that is also possible. But I need to know if its possible in the Call Manager or atleast from the Gateway side.
Chris Deren Wed, 02/15/2012 - 05:34
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Essam,
Are you wanting to make sure phones use specific device pool when they roam  from building to building?  If so then use Device Mobility feature avaialble since CUCM 4.2 and 6.0.
HTH,
Chris
Essam Nasir Wed, 02/15/2012 - 05:54
On the contrary, I don't want phones with specific device pool to roam between buildings.
Let's say, building 1 has phones configured with device pool DP1 and building 2 has phones configured with device pool DP2. Phones with device pool DP1 should not work in building 2 and vice versa. Both buildings have their own SRST gateways.
If its not possible with device pool than in what other way is this possible?
Hope its clear.
Chris Deren Wed, 02/15/2012 - 05:58
  • Hall of Fame,
By "should not work" do you mean they should not be able to register or should not be able to make any calls.
If the first one outside of what Paolo already suggested I cannot think of any other way.
If the second then you can configure Device Mobility in a way to block all calls when they are roaming at these locations.
HTH,
Chris
Essam Nasir Wed, 02/15/2012 - 06:06
Well I was thinking of the first one, but the second should also be fine.
Any idea on how I can block calls thru device mobility?
Chris Deren Wed, 02/15/2012 - 06:12
  • Hall of Fame,
Build "Physical Location" for each location, assuming you are not currently using Device Mobility, if you are no need to do this
Build device mobility group
Build New CSS that has no parition listed in it
Build Device Pools, use the new CSS as Roaming CSS
Build device Mobility info group for each subnet at the location and assign the DP to them
Assign "Physical Location" to existing DPs used by the phones.
This way when phones register at a different "Physical Location" with an IP address defined in one of the device mobility info groups they will use this roaming device pool and roaming CSS that cannot dial anything, or whatever you defined in it.
For more details on how device mobility works check out SRND and CUCM Feature and System Guides.
HTH,
Chris
