Voice gateway not registering with CCM
Answered Question
Feb 15th, 2012
Voice gateway is not registering with CCM. The causes and changes made are unknown.
2821#sh ccm-manager
MGCP Domain Name: x.x
Priority        Status                   Host
Primary         Down          x.x.x.x
First Backup    Down                  x.x.x.x
Second Backup   None
2821(config)#mgcp
%MGCP-SHUTTING-DOWN, Cannot restart MGCP until it is finished shutting down
I can also ping the CCM from the source IP address (L0) that was last registered with the CUCM
mgcp bind is also configured:
mgcp bind control source-interface Loopback0
mgcp bind media source-interface Loopback0
Please advise,
Correct Answer by Vipul Jindal about 5 years 6 months ago
run the below command to check if any port is hung up
show mgcp connection
if it is, shut and no shut the port...than perform no mgcp, mgcp.
if no port is hung up, than reload is the only workaround!!
thanks,
Vipul Jindal
please rate if it helps!!
Overall Rating: 5 (1 ratings)
Chris Deren Wed, 02/15/2012 - 09:57
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Is the domin defined?  Does it match what's on CUCM?  Have you tried "no mgcp", "mgcp"?
Chris
sindan1680 Wed, 02/15/2012 - 11:12
Domain is configured and matches the one on CCM. I tried no mgcp then mgcp and getting:
2821(config)#mgcp
Correct Answer
Vipul Jindal Wed, 02/15/2012 - 15:57
  • Cisco Employee,
thanks,
Vipul Jindal
