Warning message
Primer on policy map and srr queue/traffic shaping. Please advise!!
Feb 15th, 2012
6500 fa cabled to a 3750 gig e. 3750 is trunked to ATT transport.  For testing instead of a trunk, the int facing the 6500 is in it's own vlan.  A second int on the 3750 is placed in that same vlan and that runs to my test laptop.  P2P IP on 6500 and my laptop.  Can ping back and forth fine, run iPerf to server, etc.
When using the exact same setup in all of my tests I was able to clearly see a bandwidth limitation via iPerf output AND PRTG graph. Graph would flatten/plateau at approx 50 meg with srr queue bandwidth limit 50 set. When I put the srr queue command on a customer's interface but have it set to 10 it doesn't seem to be working. I keep seeing customer push over 10meg. Spikes, no plateau.  I have a second customer set to 45.  Still doesn't work.  They peaked at 60meg last night.
The only difference is that customer is transported from ATT cloud and my tests are to my laptop.
Works great with my laptop, doesn't work at all with customer. Both test int and customer int are switchport access vlan ###.
Basically, why is srr queue working properly with my iPerf test but not working at all when applied to a customer?
Related but not.
policy-map test
class access-match
police rate 54600000 bps burst 400000 bytes
conform-action drop
Placing this on the core interface itself kills all traffic. Int stays up but can not get anything across. access-match just points to an access list that permits any any.
I need a good QoS/rate limit/policing primer. Open to anything, at this point, as I can't get shit to work some days, some stuff doesn't work as I understand it, etc.
Took a GK switching course and not even the instructor could adequately tell me how in bloody hell I'm supposed to setup something to limit bandwidth.
Joseph W. Doherty Wed, 02/15/2012 - 18:03
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Why does your 3750 queue limit work and another 3750 doesn't?  Might be related to actual 3750 model and/or IOS.  Additionally, queue limit is noted as having several considerations; such as:
Usage Guidelines
. . . These values are not exact because the hardware adjusts the line rate in  increments of six.
This command is not available on a 10-Gigabit Ethernet interface.
Have you tried srr-queue bandwidth shape?
How did you chose your policer's burst size?  I compute it as a Tc of 58.6 ms, which seems a little long.
Kyle Gatlin Thu, 02/16/2012 - 07:05
"Have you tried srr-queue bandwidth shape?"
I have not.  I'm kind of winging it and I'm not exactly sure how to define the individual queues.
"How did you chose your policer's burst size?  I compute it as a Tc of 58.6 ms, which seems a little long."
I was under the impression that calculating TC is only necessary when using a policer, cir, bc, and be rates?  If this is not the case, I would definitely appreciate some expanded information.
srr queue bandwidth limit 50, for example, is on two interfaces on the same 3750.  One, a customer, it doesn't work on.  The other, for testing, it works great.  At the moment I assume that maybe since iPerf is an extended burst of traffic and the customer is not, srr queue is queuing the test interface correctly and not the customer.
I'm using "police rate 54600000 bps burst 400000 bytes" under the impression that the rate lets me define the amount of bandwidth to use (in bits) while burst (in bytes) is the allowance over that bandwidth.
Thank you very much for your reply.
Joseph W. Doherty Thu, 02/16/2012 - 10:51
Disclaimer
Posting
"I have not.  I'm kind of winging it and I'm not exactly sure how to define the individual queues."
Yes, that can be complex although in your case, if all the packets are marked the same, all packets should go to same queue, and only it would need to be configured to shape.
"I was under the impression that calculating TC is only necessary when  using a policer, cir, bc, and be rates?  If this is not the case, I  would definitely appreciate some expanded information."
Whether you need to calculate Tc depends on your policer requirements.  Usually defaults are either 4 or 25 ms.  Did you explicitly enter 400000, or did you leave it blank and the system provided it?
"I'm using "police rate 54600000 bps burst 400000 bytes" under the  impression that the rate lets me define the amount of bandwidth to use  (in bits) while burst (in bytes) is the allowance over that bandwidth."
No, burst sets the measurement period, indirectly.  It counts bytes (bits) for the against the specified rate.  Remember, physically, actually transmission is at media bandwidth.  What a policer does is measure how many bits are actually transmitted during some Tc and drop excess within that period.
Kyle Gatlin Thu, 02/16/2012 - 11:09
How did you calculate TC for the police rate above?
I've tried multiple things today.  Essentially, we have our core network with upstreams to L3, Cogent, etc.  From our core we provide service to other ISPs, customers, etc.  I need to figure out a good method of limiting bandwidth egress/out to customers from our Core.
What I have run into today again is that srr-queue bandwidth limit 50 is limiting both in and outbound traffic on my test circuit, but when ever I place that same limitation on a customer circuit, nothing happens.  I assume maybe srr queue limit is ingress only, but with iPerf doing bi directional traffic, limit works fine on test interface in/out.  So now I'm assuming that maybe because our customers burst often, srr queue may not be affecting traffic.  However, one particular customer regularly goes over the bandwidth they pay for and are limited too.
So, as far as srr queue limit goes, it simply doesn't work on a customer interface.  I've played around with multiple srr-queue shape/share numbers and those have no effect at all.  The only difference is that I kill all traffic on an interface before changing srr-queue settings where as I merely added srr-queue to customer's interface while they were still pushing traffic.
Kyle Gatlin Thu, 02/16/2012 - 11:29
Testing with the shape command.
srr-queue bandwidth shape 5 5 5 5
This seems to be working where as 5 0 0 0 did not.  show mls qos interfaces queue shows that the int is in "queue set 1", which I assumed was the first digit.
Joseph W. Doherty Thu, 02/16/2012 - 17:06
Disclaimer
Posting
The 5 5 5 5 would enable shaping on all 4 egress queues, equally each 20% (1/5).  5 0 0 0 would only shape on queue 1, others would be in share mode.
Queue set 1 is the default.  There's also a queue set 2.  Allows two different sets of some of the parameter to be selected for a port.  Can be useful if you want to treat edge ports differently from uplink ports.
Joseph W. Doherty Thu, 02/16/2012 - 16:59
Disclaimer
Posting
400000 * 8 / 54600000 = 58.6 ms
Related Content
