cli - associating users with phones
Feb 15th, 2012
In the gui this is self explanatory, but would like to be able to reassign / create new users / associate users with phones at the CLI of our UCS 560. I see some of the relevant sections, below, but not where the mac address of the phone actually gets associated with the user. What's the relevant parts of the config to make that happen at the CLI? Thanks
ephone  33
device-security-mode none
mac-address C062.6BD2.472A
ephone-template 15
max-calls-per-button 2
username "New.018" password 123456
type 7931
button  1:556 2m572 3m570 4m592
button  5m591 6m589 7m587 8m594
button  9m593 10m596 11m597 12m588
button  17m583 18m584 19m585 20m586
(snip)
ephone-dn  556  octo-line
number 842 no-reg primary
label Test-842
description Test User
name Test User
call-forward busy 399
call-forward noan 399 timeout 20
David Trad Wed, 02/15/2012 - 15:41
  • Gold, 750 points or more
  • Cisco Designated VIP,
    2013 Small Business
Hi Chris,
You are looking right at it
"ephone  33" is the phone configuration not the user configuration
"ephone-dn  556" is the user configuration with also call routing rules which is not done on the ephone
To associate a user to a phone you would need to ensure that the correct MAC address is associated to the ephone (Not the DN) and that the correct button assignment is in place for instance, button 1:556 on the above ephone is pointing to ephone-dn 556, so this completes the association.
Now a couple of things you need to remember:
  1. CLI changes are not covered under support unless you are UC express certified
  2. If the changes are different to how CCA creates it or makes it or even changes it, then CCA might delete that configuration completly, or CCA will not like it and just ignore the whole thing
  3. Doing CLI changes may also put your system out of SBSC scope
You need to fully understand what you are doing and what impact the changes may have on the system, if you are not well versed in CLI, or CCA-OOB changes then I am obligated to let you know that you could be causing yourself many headaches
Just out of curiosity, why do you want to do CLI? Is it as a learning experiencing, or understanding what goes on under the hood?? Or for conducting remote configuration where the GUI cannot be used???
If you need more help just ask
Cheers,
David.
lscd-fort Wed, 02/15/2012 - 18:35
Thanks for the reply David, a big help, that does make sense now that I look at button 1. I assume button 1 is the 'identity' for the phone <-> user association?
I'm not a cisco ucs expert, but have worked with a shoretel system in the past, so I'm familiar with most of the concepts.
I'm a linux systems person, so yes to both of your questions, I do want to absolutely know what's going on under the hood. Also I'm only at this site about 2 weeks per month, rest of the time I have an ssh prompt into the network with vpn. So being able to manage from command line is a huge plus for me. Being able to run debugs to see where calls are going and why is also a big plus.
I version control and checksum all my configs, so the concept of change history of the config makes sense for me. All this being said, I can appreciate the gui, however can everything realistically be configured from the CLI? Or are there some things that have to be done from the gui?
Thanks so much for your help and I imagine I'll have a couple more questions from time to time.
David Trad Wed, 02/15/2012 - 19:25
    2013 Small Business
Hi Chris,
There is a story behind the push for using the GUI too long to write out and probably no point venturing down that track at this point... Suffice to say, that the GUI is the primary method in which Cisco will give you support on, CLI support on these SMB devices is waning away, and their is a genuine need to do so.
CCA for what its worth, is a key critical component in maintaining and managing a UC-500 system, it also structures the system in the way that Cisco would prefer them to be deployed in, it remove the ability of Cow Boy CLI jockey's leaving a client high and dry with a badly configured system, and further to that fortifies the support mechanism as 95% of the UC-500 deployments will be consistently the same, minus the required customization that would be required, but the configuration structure is fundamentally the same.
If you have VPN access into the network than CCA can still manage it, you don't do things like IOS/CUE upgrades over the WAN you leave that till you are on-site, but all ad-hoc modifications can and should be done by CCA.
Updating and modifying the system via CLI should be your last resort, if there is any inclination of getting an SBSC contract on the system, then CLI will have to be 100% excluded without explicit permission from SBSC to do such CLI changes, others you void the support contract... Even if no support, if you want the majority of us on here to be able to support you to our fullest capacity, then using the GUI will get the best of us, even though most of us a originally CLI trained (Those of us who are not Cisco employed but love to help out on here).
I can only encourage you to give CCA a proper go, be committed to using it, if it doesn't work out for you then feel free to go to CLI, and yes you can make 100% of the changes via CLI, wether it be the right way or not is another thing.
Cheers,
David.
lscd-fort Wed, 02/15/2012 - 20:14
Thanks David, I can appreciate the support aspect.
Another question, how to swap users / phones, which was one of my original goals. i.e., a user is changing desks. Let's say in the GUI. ; )
Maybe just as simple as changing the button 1 config in the GUI, swapping the users ext with an unused ext? Or is it acceptable practice to delete/re add the phone, that way you can set up the user id, etc as you want? Seems one just needs the mac address, and you can add a phone back in.
David Trad Thu, 02/16/2012 - 04:24
    2013 Small Business
Hi Chris,
I dont know about others but I just move the physical phones around
Out side of that standard practice is to delete and recreate the user in CCA, in the old days this would be done easily via CLI without having to remove the user, but the close integration with the CUE requires deletion now, you can avoid doing this if you keep the user name generic, I tend to use ID numbers instead of names so they can be used with anyone
Hope that helps...
Cheers,
David.
lscd-fort Wed, 02/22/2012 - 06:35
Hi David, does the ucs 560 require MS sbs ? We have an sbs 2011 server and will be replacing it in the coming weeks.
