VLANs in WLC
Feb 15th, 2012
HI,
I went through below link
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008073c723.shtml
I have the same setup except the dhcp.
I have dhcp server which is givng IP to clients; I want to divide clients as bulding 1 and building 2 with vlan
But they should get IP from same dhcp server
how can I do it?
nikhilcherian Wed, 02/15/2012 - 23:39
  • Bronze, 100 points or more
Have you created ap-group per building and did interface over-ride
NikhiL
nikhilcherian Thu, 02/16/2012 - 00:58
Configure it like this
Create AP-Groups in the WLC for each of the building
Create dynamic interfaces for each building
Under WLAN>Ap-Groups, add each AP in each building, in the respective AP-Groups
Map the WLAN to the AP-groups to the interface for each building ( you can see an option, Add interface mapping in the document you sent)
NikhiL
vishalpatil86 Thu, 02/16/2012 - 01:32
what about the vlan,
i need to configure vlan 4000 and 4001
first buldng aps will be in vlan 4000 and second bldng will be in 4001
right now i have only 4001 enabled
nikhilcherian Thu, 02/16/2012 - 01:37
Create VLAN 4000 also and configure the AP port in VLAN 4000. If you want the client to get ip address in vlan 4000, create a dynamic interface in the WLC in vlan 4000 and map it to the WLAN
NikhiL
