FlexConnect (aka H-REAP) and Auto-Anchor functionality
Answered Question
Feb 16th, 2012
Hi Board,
I never did H-REAP on my wireless deployments. Now, I have an H-REAP (FlexConnect) requirement for branch offices.
Also there is the requirement for guest access at the same time.
From my understanding those features (FlexConnect and Auto-Anchor) should work together.
Please refer to the following exibit:
There is a FlexConnect AP at my branch office. The traffic from internal users (SSID "Internal") should be switches locally at the LAP (Lightweight Access Point). At the same time the guest SSID (SSID "Guest") should be tunneled back via CAPWAP to the controller to which the LAP is associated ("Central Controller"). The guest traffic should not emerge (switched) at the "Central Controller", instead it should be tunneled to an anchor controller in a DMZ via an "Ethernet Over IP tunnel" (Auto-Anchor functionality).
First question: Does this work (FlexConnect in conjunction with Auto-Anchor functionality)?
If this works, where's the web portal for guest authentication hosted (if using the internal web auth on WLC)? On the "central controller" or the Anchor controller? (I guess at the Anchor Controller in the DMZ, right?)
Is it possible to leave the guest SSID "open" with no webauth and still using the Anchor Controller? This would be needed if I have an external web authentication service, which would be hosted by a provider.
Thanks in advance for all your replies!
Johannes
Correct Answer by Scott Fella about 3 years 12 months ago
Yes that is what you want.... WLC5508-12.
Your statement is in fact correct.  Your guest traffic will be sent back to the flexconnect wlc or wlc and then you would anchor that SSID to the dmz SSID.  The anchor wlc in the dmz will host the webauth, passthrough splash page. This would be the same if you just wanted open auth. Anchoring works either way.  Make sure these ports are open between the anchor and remote wireless LAN controller: UDP 16666 or IP 97
Overall Rating: 5 (4 ratings)
Correct Answer
Scott Fella Thu, 02/16/2012 - 04:17
Johannes Luther Thu, 02/16/2012 - 08:08
Thank you so much for the answer. One last question if I may:
The anchor controller can be licensed with the smallest AP count, right?
So a 5508 with 12 AP support should do the job.
There are no APs associated at the anchor controller
ldandrea Tue, 05/22/2012 - 09:52
From the diagram, can I use a Flex 7500 instead of the 5508 in the central location?
Johannes Luther Wed, 05/23/2012 - 00:52
The Flex 7500 deployment guide ("
http://www.cisco.com/en/US/products/ps11635/products_tech_note09186a0080b7f141.shtml
") states:
"The Cisco FlexConnect Solution also supports  Central Client Data Traffic, but it should be limited to Guest data  traffic only."
later in the document there is a section about Guest access that states "Flex 7500 will allow and continue to support creation of EoIP tunnel to your guest anchor controller in DMZ."
Hope that helps.
Vinay Sharma Sun, 04/29/2012 - 04:32
The document was generated from the following discussion:-
https://supportforums.cisco.com/docs/DOC-24096
Related Content
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
