Warning message
VPN users connect but can't access LAN servers
Feb 16th, 2012
I have a ASA 5505 and setup SSL VPN. My users can connect to the VPN but can't get access to any of the internal servers. Can someone tell me what I am missing?
Kimberly Adams Thu, 02/16/2012 - 10:56
  • Silver, 250 points or more
It would be very helpful if you could post your configuration.  But initially my first thought, without seeing the configuration, is your LAN or LANS allowed in your access-lists for the VPN?
Kimberly
rohaverm Thu, 02/16/2012 - 11:05
I hope the configuration you are talking about is of SSL Client. Non of the internal servers are accessible.So considering it to be "tunnel all", check NAT exemption between the inside subnet and client pool if interface access-li (if any) is at its place.
RV
Jeff Van Houten Thu, 02/16/2012 - 18:54
Do your servers have a route to the VPN client addresses?
