problem with fcoe (brocade cna & nexus 5596)
Feb 16th, 2012
We are currently troubleshooting an FCOE connection from a server to a nexus 5596.
the cna card is a brocade 1860 firmware is at 3.0.0.0 and the nexus os is at  5.1(3)N1(1)
the pwwn of the server cna card never shows up in the flogi database....
the cna interface is connected to ethernet 1/15 interface
i did a show lldp interface 1/15 and i can see that there's a peer at the other end.
Ethernet1/15 is up
  Hardware: 1000/10000 Ethernet, address: 547f.ee26.fd16 (bia 547f.ee26.fd16)
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec
  Encapsulation ARPA
  Port mode is trunk
  full-duplex, 10 Gb/s, media type is 10G
  Beacon is turned off
  Input flow-control is off, output flow-control is off
  Rate mode is dedicated
  Switchport monitor is off
  EtherType is 0x8100
  Last link flapped 00:00:06
  30 seconds input rate 240 bits/sec, 0 packets/sec
  30 seconds output rate 0 bits/sec, 0 packets/sec
  Load-Interval #2: 5 minute (300 seconds)
    input rate 32 bps, 0 pps; output rate 760 bps, 1 pps
  RX
    0 unicast packets  2323 multicast packets  160 broadcast packets
    2483 input packets  249974 bytes
    0 jumbo packets  0 storm suppression bytes
    0 runts  0 giants  0 CRC  0 no buffer
    0 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    1 unicast packets  145578 multicast packets  241 broadcast packets
    145820 output packets  11055457 bytes
    0 jumbo packets
    0 output errors  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble 0 output discard
    0 Tx pause
  17 interface resets
Ethernet1/15 is FCoE UP
    vfc1 is Up
vfc1 is trunking
    Bound interface is Ethernet1/15
    Hardware is Ethernet
    Port WWN is 20:00:54:7f:ee:26:fd:3f
    Admin port mode is F, trunk mode is on
    snmp link state traps are enabled
    Port mode is TF
    Port vsan is 1
    Trunk vsans (admin allowed and active) (1)
    Trunk vsans (up)                       ()
    Trunk vsans (isolated)                 ()
    Trunk vsans (initializing)             (1)
    1 minute input rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
    1 minute output rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
      0 frames input, 0 bytes
        0 discards, 0 errors
      0 frames output, 0 bytes
    last clearing of "show interface" counters never
    Interface last changed at Thu Feb 16 15:21:40 2012
sh vsan 1
vsan 1 information
         name:VSAN0001  state:active
         interoperability mode:default
         loadbalancing:src-id/dst-id/oxid
         operational state:up
vsan 1 interfaces:
    fc1/44            fc1/45            fc1/46            fc1/47
    fc1/48            vfc1
    vfc1 is Up
sh vsan 1
vsan 1 information
vsan 1 interfaces:
    fc1/48            vfc1
can you help me on this ?
thanks
zawoo Thu, 02/16/2012 - 22:39
Can you do "show run interface e1/15" and also "show fcoe vlan"? If we are not allowing the native vlan and fcoe vlan on the Ethernet interface you might see a issue similar to what you are seeing now. Also make sure "spanning-tree port type edge trunk" on ethernet interface assuming you have all the latest and greatest firmware update for your cna already.
Kris Vandecruys Fri, 02/17/2012 - 05:32
Hi all,
I can shed some light here.  It's very likely that you're indeed running into the issue Erik described.  What's happening is that the CNA might be using the old Gen1 protocol, CIN.  Nexus5500 series no longer support this, in favor of the more modern and standard CEE.
You can easily check this.  Run this command on the affected interface:
# show system internal dcbx info interface Ethernet1/15
You'll see an output similar to this:
Interface info for if_index: 0x1a002000(Eth1/15)
tx_enabled: TRUE
rx_enabled: TRUE
dcbx_enabled: TRUE
DCX Protocol: CIN
That last line should read 'DCX Protocol: CEE' for it to work on a 5500 series.
Hope this helps!
/Kris
zawoo Tue, 02/21/2012 - 10:34
Also make sure you have the following FCoE QoS policies explicitly define:
system qos
   service-policy type qos input fcoe-default-in-policy
   service-policy type queuing input fcoe-default-in-policy
   service-policy type queuing output fcoe-default-out-policy
   service-policy type network-qos fcoe-default-nq-policy
Dennis Goh Mon, 03/05/2012 - 08:50
I've also happened to encounter this issue. Any reason why system qos service policies can affect the protocols used? If I do not explicitly define these policies, I can see that the DCX protocol used is still CIN. Once these lines are implemented, you perform a "show system internal dcbx info int eX/X" DCX protocol you will see CEE.
desrochj1 Fri, 02/17/2012 - 07:08
Hello Kris,
the cna card seems to run CEE protocol
sh system internal dcbx info interface ethernet 1/15
Interface info for if_index: 0x1a00e000(Eth1/15)
tx_enabled: TRUE
rx_enabled: TRUE
dcbx_enabled: TRUE
DCX Protocol: CEE
DCX CEE NIV extension: disabled
here's the show run for the server interface
switchport mode trunk
here's the show vlan fcoe
sh vlan fcoe
Original VLAN ID Translated VSAN ID Association State
889 1 Operational
lamav Sun, 02/19/2012 - 19:04
Have you bound the VSAN to the FCoE VLAN?
example:
vlan 1000
  fcoe vsan 2
  name FCoE_VLAN
Trending Topics: Storage Networking
