Can't hear MOH from PSTN, help
Answered Question
Feb 16th, 2012
hi, I have a problem, And it is some messy :S
1.- I have a router with IOS 15.
2.- The router has a PSTN E1 voice Link.
3.- The router is conected to two call managers.
     3.1 One Call Manager is conected through a voice IP Dial Peer.
dial-peer voice 3000 voip
destination-pattern 7771...
modem passthrough nse codec g711ulaw
session target ipv4:10.252.10.10
dtmf-relay h245-alphanumeric h245-signal
codec g711ulaw
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback cisco
ip qos dscp cs3 signaling
no vad
3.2 The other Call Manager is conected from another Dial Peer, for other extensions.
dial-peer voice 3001 voip
preference 1
destination-pattern 777....
session target ipv4:10.2.10.20
codec g711ulaw
no vad
4.- Both Call managers are conected each other through a Intercluster Trunk, so they can transfer Calls.
5.- We configure the router as the MOH source, cause we don want call manager source for MOH.
10  -rw-      267262  Feb 13 2012 15:55:24 -06:00  music-on-hold.wav (ulaw, 8000 (mono))
     5.1 Our file MOH is on the flash on our router, as follow:
call-manager-fallback
max-conferences 2 gain -6
transfer-system full-consult
timeouts interdigit 6
ip source-address 10.252.40.40 port 2000
max-ephones 700
max-dn 300 dual-line
system message primary CSF SRST
huntstop channel
moh flash:music-on-hold.wav
multicast moh 239.1.1.1 port 16384 route 10.252.40.40
date-format dd-mm-yy
6.- Out Voice Router only have one interface to the network
Interface                  IP-Address      OK? Method Status                Protocol
GigabitEthernet0/0         10.252.40.40 YES NVRAM  up                    up
GigabitEthernet0/1         unassigned      YES NVRAM  administratively down down
Tunnel0                    10.252.40.40 YES unset  up                    up
Tunnel1                    10.252.40.40  YES unset  up                    up
7.- We don't listen the desire MOH audio source as the follow:
     7.1 We can hear them between internal IP Phones.
     7.2 We can not hear them for a specific DID (Direct Inward Dial) form the PSTN. (only silence)
8.- Please help me
Data
Cisco IOS Software, 3800 Software (C3845-SPSERVICESK9-M), Version 15.1(4)M, RELEASE SOFTWARE (fc1)
Cisco 3845 Router
I already used the command "NO IP CEF"
Please, help me.
Correct Answer by Chris Deren about 5 years 6 months ago
In order to play MOH from flash to PSTN callers you need to define a lookback interface (does not need to be routeable) and include it under the multicast moh line, i.e.
multicast moh 239.1.1.1 port 16384 route 1.1.1.1 10.252.210.135
where 1.1.1.1 is the loopback IP.
HTH,
Chris
Overall Rating: 5 (2 ratings)
Correct Answer
Chris Deren Thu, 02/16/2012 - 09:49
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
HTH,
Chris
Juan Gerardo He... Thu, 02/16/2012 - 15:00
Hi, Chris Deren,
5 Star my friend, your comment was very helpful, actually, it solve the problem for PSTN to DID's MOH.
But I stil have another MOH Problem, hope u' can help me on this.
1.- Incomming call from PSTN to Local (First) Call Manager 10.252.10.10.
2.- Answer Autoattendant, asking for the user to enter a valid phone number.
3.- Redirecting to number.
     3.1 The Ip phone is in the other Call Manager Cluster 10.2.10.20
4.- The user answer the call.
5.- The user pess the "hold button"
6.- Default MOH of call manager hears! Not the one configured on the router. :S
Call  manager 1 can transfer the calls to call manager 2 using a  Inter-Cluster Trunk (Non-Gatekeeper Controlled). But I dont know if it  is a blind transfer (full) or a partial transfer where Original Call  Manager who anser the call have to still participate.
Anyway, the default, MOH plays and not the configured MOH.
Could you please help me?
Marwan ALshawi Thu, 02/16/2012 - 15:11
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
if this is UCCX maybe the MOH source will be used based on what is configured on the CIT port !!!
Related Content
