AP 1131 as office extend w/local ssid?
Answered Question
Feb 16th, 2012
I have an 1131ag AP attached to our 5508 as an OEAP over the Internet.  Everything with the corporate SSIDs is working correctly, so no issue there.  I was wondering if a local ssid can be configured on the AP, similar to what can be done with the OEAP600, in order to provide wireless access to the Internet only?  On the WLC, on the H_REAP tab, there is a button labeled "Reset Personal SSID", so I am guessing that there must be a way to do it-I just can't seem to find out how.  TIA.
Correct Answer by blakekrone about 5 years 3 months ago
You would set a username/password on the AP from the WLC AP GUI. Once this is set provide that to the end user, they will then browse the AP using HTTP via the IP of the AP from the local DHCP server. They can then login and create their personal SSID.
Overall Rating: 5 (1 ratings)
Correct Answer
blakekrone Thu, 02/16/2012 - 14:00
  • Silver, 250 points or more
Jack Nicholson Thu, 02/16/2012 - 14:07
Awesome.  That was exactly what I needed to know.  Thanks for the help and the ultra quick answer!
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
