Warning message
NAT problem, anyconnect clients cant reach dmz?
Answered Question
Feb 9th, 2012
ASA 8.3
Anyconnect users can reach INSIDE, but not DMZ. Dmz host 10.120.1.2 is what I am trying to reach.
Packet-tracer shows it should be possible. Attaching my asa config.
What am I missing?
¨Packet-tracer:
asa-kalasa# packet-tracer input vpn tcp 172.16.32.4 50545 10.120.1.2 22
Phase: 1
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Additional Information:
in   10.120.1.0      255.255.255.0   dmz
Phase: 2
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group dmz_access_in in interface dmz
access-list dmz_access_in extended permit ip any any log disable
Phase: 3
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 4
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group dmz_access_out out interface vpn
access-list dmz_access_out extended permit ip any any log disable
Phase: 5
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 6
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 32484740, packet dispatched to next module
Result:
input-interface: dmz
input-status: up
input-line-status: up
output-interface: dmz
output-status: up
output-line-status: up
Action: allow
Correct Answer by Julio Carvajal about 5 years 6 months ago
On the Nat statements, instead of using the Any Any use the object groups for each network like:
nat (inside,outside) source staticy OFFICE-NET  OFFICE-NET  destination static NETWORK_OBJ_172.16.32.0_24 NETWORK_OBJ_172.16.32.0_24
Same for the DMZ
Julio
Overall Rating: 5 (1 ratings)
3moloz123 Thu, 02/16/2012 - 23:58
Bumping this thread. Surely, someone must be able to help me debug this further?
3moloz123 Fri, 02/17/2012 - 00:17
I have isolated the problem to these two rules:
6 (inside) to (outside) source static any any destination static ipsecvpnpool ipsecvpnpool
    translate_hits = 4997, untranslate_hits = 34889
5 (dmz) to (outside) source static any any destination static ipsecvpnpool ipsecvpnpool
    translate_hits = 0, untranslate_hits = 0
Here, anyconnect can reach inside, but not dmz. If I however change the order of the nat rules, then anyconnect can reach dmz but not inside.
Correct Answer
Julio Carvajal Fri, 02/17/2012 - 20:05
  • Purple, 4500 points or more
Same for the DMZ
Julio
3moloz123 Tue, 02/21/2012 - 00:00
Hi jcarvaja!
That did indeed work. Im not sure why any any wouldn't be as good as a match, as it clearly must differ on what interface the packet comes in on. Anyway, thank you for the answer,
Julio Carvajal Tue, 02/21/2012 - 09:24
Hello 3moloz,
Glad to hear I could help! yeap usually the any any on a nat statement causes a lot of issues do to arp problems.
Julio
