Can't connect to HOSTNAME.local.
Feb 17th, 2012
Hi!
I have installed Cisco FindIT.
My SG 200-08 Switches are visible in the sidebar.
When i hover over one of my switches the tooltip display all my Switchinfos.
When i open a switch i get an error of dns-resolution.
FindIT try to connect to the Switch at HOSTNAME.local. and fail.
Why can't FindIT get my configured domain-suffix?
Where can i change the Domain-suffix?
David Harper Sun, 02/19/2012 - 16:50
  • Cisco Employee,
This is pretty unusual.  FindIT and the 200 series switches have been well tested to ensure interoperability.  Can you provide a few more details?  In particular, the version firmware running on the switch, the version of FindIT that you are running, the IP address of your PC, and a screenshot of the FindIT balloon showing the switch details?
Cheers,
Dave.
mreisner Mon, 02/20/2012 - 00:50
My PC is domain member and i use the same DHCP-Server as the SG 200-08 Switches.
The SG 200-08 Switches are getting their IP-Adress and domaininformations from the DHCP-Servers.
FindIT broadcasts MDNS. So the Switches are on the same subnet as my workstation.
At the Screenshot you can see the informations of the Switches, the errormessage and the Version of FindIT.
Kind regards
Martin
Nagaraja Thanthry Mon, 02/20/2012 - 13:45
  • Cisco Employee,
Can you please verify if there is an entry for the switch name in your DNS server? If it is a local network, is there a WINS server that keeps track of the local names? Can you edit the "hosts" file on the PC and add an entry for the switch name and see if the name gets resolved?
C:\Windows\System32\Drivers\etc\hosts
Nagaraja
David Harper Mon, 02/20/2012 - 18:14
  • Cisco Employee,
Ok, assuming you are able to connect to other device correctly using FindIT, this does tend to indicate a problem with the switch.  We release the 1.0.2.0 firmware update for these switches a couple of weeks ago, so it would be worth upgrading the firmware on the switch and see if the problem gets addressed.  I'm not aware of any specific bugfixes in that release that would address this, but I haven't been through the full list of fixes to confirm.
In the meantime, I'll have a talk to engineering and see if they have seen this before.
Cheers,
Dave.
mreisner Tue, 02/21/2012 - 02:03
Thank you for your reply.
I will try version 1.0.2.0.
I have many networks with 186 of the SG200-08.
Every SG200-08 on every network shows the same issue.
Our DNS-Servers are updated by the DHCP-Servers.
The Entry for the Switche are OK in both directions.
In the Sniffertrace you can see the MDNS-Query:
_csco-sb._tcp.local: type PTR, class IN, "QM" question
_csco-config._tcp.local: type PTR, class IN, "QM" question
The MDNS-Responses from the switches are like:
switchCB7ED8._csco-sb._tcp.local: type TXT, class IN, cache flush
hostname=swfo0077
.local. is send by the switches.
