I am programmin XML applications to be used in 303, 50xG spa telephones. When you send a <CiscoIPPhoneText> it stays there until pressing Cancel. Is there a way of having a timeout (say 2 seconds) so the Text dissapears without having to press anything. The situation is worse for the <CiscoIPPhoneInput>, after submiting it doesn't dissapear, so if the answer to the URL is <CiscoIPPhoneText> then the user has to press cancel twice to clear the screen.
Thank you, Diego
