ipv6, ospfv3 virtual-link
Answered Question
Feb 17th, 2012
  • Bronze, 100 points or more
Hi  everybody.
I am trying to establish a virtual link between R3 and R2 so area 2 can connect to area 0 and R1 will learn R4's loopback prefix 2000::4/128.
Detail is given below:
R1--s0/0---area 0---s0/0-R2--s0/1--area 1---s0/1-R3--s0/0---area 2-----s0/0--R4
All the above routers's serial interfaces are configured with " ipv6 address autoconfig".
R1's id 1.1.1.1, R2's id 2.2.2.2, R3's id 3.3.3.3,R4's id 4.4.4.4
R4 has loopback address 2000::4/64.
R3 is learning 2000::4/128 from R4.
As expected, R1 is not learning this route because  area 2 is not yet connected to it.
Now if we configure a virtual-link between R3 and R2 ,  R1 should know 2000::4
But for some reasons, R1 is not learning this route.
R3#show ipv6 route
IPv6 Routing Table - 4 entries
Codes: C - Connected, L - Local, S - Static, R - RIP, B - BGP
       U - Per-user Static route, M - MIPv6
       I1 - ISIS L1, I2 - ISIS L2, IA - ISIS interarea, IS - ISIS summary
       O - OSPF intra, OI - OSPF inter, OE1 - OSPF ext 1, OE2 - OSPF ext 2
       ON1 - OSPF NSSA ext 1, ON2 - OSPF NSSA ext 2
       D - EIGRP, EX - EIGRP external
C   2000::/64 [0/0]
     via ::, Loopback3
L   2000::3/128 [0/0]
     via ::, Loopback3
O   2000::4/128 [110/64]
     via FE80::C203:12FF:FEC0:0, Serial0/1
L   FF00::/8 [0/0]
     via ::, Null0
Below is the virtual-link configured at R3:
pv6 router ospf 1
router-id 3.3.3.3
log-adjacency-changes
area 1 virtual-link 2.2.2.2
Virtual-link configuration at R2:
ipv6 router ospf 1
router-id 2.2.2.2
area 1 virtual-link 3.3.3.3
Routing table  at R1 is shown below:
R1#show ipv6 route
OI  2000::3/128 [110/128]
     via FE80::C201:12FF:FEC0:0, Serial0/0
L   FF00::/8 [0/0]
     via ::, Null0
The prefix 2000::4/128 is missing even though virtual-link is configured between R2 and R3.
Below   I have pasted the configurations:
R1#show running-config
Building configuration.
ipv6 unicast-routing
interface Serial0/0
no ip address
ipv6 ospf 1 area 0
clock rate 200000
ipv6 router ospf 1
router-id 1.1.1.1
R2's config
R2#show running-config
Building configuration...
Current configuration : 1113 bytes
version 12.4
hostname R2
interface Serial0/0
no ip address
ipv6 ospf 1 area 0
clock rate 2000000
interface Serial0/1
no ip address
ipv6 ospf 1 area 1
clock rate 2000000
ipv6 router ospf 1
router-id 2.2.2.2
R3's config:
R3#show running-config
Current configuration : 1195 bytes
version 12.4
interface Loopback3
no ip address
ipv6 address 2000::3/64
ipv6 ospf 1 area 1
interface Serial0/0
no ip address
ipv6 ospf 1 area 1
clock rate 2000000
interface Serial0/1
no ip address
ipv6 ospf 1 area 2
clock rate 2000000
ipv6 router ospf 1
router-id 3.3.3.3
R4's config:
R4#show running-config
Current configuration : 1132 bytes
version 12.4
interface Loopback14
no ip address
ipv6 address 2000::4/64
ipv6 ospf 1 area 2
interface Serial0/0
no ip address
ipv6 ospf 1 area 2
clock rate 2000000
ipv6 router ospf 1
router-id 4.4.4.4
thanks  and have a nice weekend.
Correct Answer by lgijssel about 5 years 4 months ago
Hi Sarahr,
I have tested your case on GNS3. This provided an intersting result.
On the 3640 with IOS c3640-jk9s-mz.124-16 it did not work, I could not even establish ospf neighbors.
Then I decided to move the lab to a 3745 using IOS Version 12.4(15)T6.
To my surprise it worked almost at once, for some reason the new R1 did not take the modified config but after correcting this GNS-related problem, everthing was ok. This is some output from R1:
R1#sh ipv6 ro
IPv6 Routing Table - 7 entries
LC  2000::1/128 [0/0]
     via ::, Loopback0
OI  2000::2/128 [110/64]
     via FE80::C201:12FF:FEC0:0, Serial1/0
OI  2000::4/128 [110/192]
C   2001:2::/64 [0/0]
     via ::, Serial1/0
L   2001:2::2/128 [0/0]
     via ::, Serial1/0
L   FF00::/8 [0/0]
     via ::, Null0
R1#
This implies your config is correct and the problem is with the IOS version or so.
Are you using GNS as well?
I can send the lab via email if you want.
regards,
Leo
Overall Rating: 5 (1 ratings)
Correct Answer
lgijssel Sat, 02/18/2012 - 02:17
  • Red, 2250 points or more
Hi Sarahr,
R1#sh ipv6 ro
     via ::, Loopback0
C   2001:2::/64 [0/0]
     via ::, Serial1/0
     via ::, Serial1/0
L   FF00::/8 [0/0]
     via ::, Null0
R1#
regards,
Leo
