Site-to-site VPN issue using ASA version 8.2(5)
Answered Question
Feb 18th, 2012
Well I’ve configured site-to-site vpns using ASDM several times before and everything went smoothly using the ipsec wizard , recently I got one ASA with version 8.2(1) and another with version 8.2(5) both are out of the box . The tunnel comes up normally if initiated from version 8.2(1) but no communication can come through, since using packet tracer I noticed that the 8.2(5) version ASA was dropping packets destined to the other site, though the access lists created by asdm seemed fine.
I’ve also noticed that in packet tracer in version 8.2(1) these steps were listed:
Flow-Lookup->Route-lookup->IP-Options->Nat-exempt->Nat->Nat->Host-limit->VPN->flow-creation->Result- The packet is allowed
While in version 8.2(5)
Access-list (which points to an access list that doesn’t show in access list table since its default as a message window indicates when clicking on show rule in access table) -> Route-Lookup-> then gets dropped by the inside network implicit deny rule) (acl-drop) flow is denied by configured rule
I appreciate any help concerning this issue, here is the config of both ASAs, I’ve already checked if there was a configuration mismatch and tried finding the changes in config between the 2 versions but wasn’t able to find anything significant also tried configuring through CLI but some command I used were depreciated by cisco and I guess it might be something related to the default setting related to the 8.2(5) version
ASA Version 8.2(5)
Uses internal network: 192.168.10.0
ASA Version 8.2(1)
Uses internal network: 192.168.1.0
ASA Version 8.2(5)
hostname xxxxx
domain-name xxxxxx
names
name 192.168.1.0 remote
interface Ethernet0/0
switchport access vlan 2
interface Vlan1
nameif inside
security-level 100
ip address 192.168.10.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
pppoe client vpdn group ppoe
ip address pppoe setroute
ftp mode passive
dns server-group DefaultDNS
domain-name xxxxx
access-list outside_1_cryptomap extended permit ip 192.168.10.0 255.255.255.0 remote 255.255.255.0
access-list inside_nat0_outbound extended permit ip 192.168.10.0 255.255.255.0 remote 255.255.255.0
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 0.0.0.0 0.0.0.0
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http remote 255.255.255.0 inside
http 0.0.0.0 0.0.0.0 outside
http 192.168.10.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set peer x.x.x.x
crypto map outside_map 1 set transform-set ESP-DES-MD5
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption des
hash sha
group 2
lifetime 86400
crypto isakmp policy 30
encryption des
hash md5
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
vpdn group dsl request dialout pppoe
vpdn group dsl localname xxxxxx
vpdn group dsl ppp authentication chap
vpdn username xxxxxx password ***** store-local
dhcpd auto_config outside
dhcpd address 192.168.10.5-192.168.10.32 inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy DfltGrpPolicy attributes
tunnel-group x.x.x.x type ipsec-l2l
tunnel-group x.x.x.x ipsec-attributes
pre-shared-key *****
prompt hostname context
no call-home reporting anonymous
ASA Version 8.2(1)
hostname yyyyy
domain-name yyyyyy
names
name 192.168.10.0 remote
interface Vlan1
nameif inside
security-level 100
ip address 192.168.1.101 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address x.x.x.x 255.255.255.248
ftp mode passive
dns domain-lookup inside
dns domain-lookup outside
access-list outside_1_cryptomap extended permit ip 192.168.1.0 255.255.255.0 remote 255.255.255.0
access-list inside_nat0_outbound extended permit ip 192.168.1.0 255.255.255.0 remote 255.255.255.0
pager lines 24
logging enable
mtu inside 1500
mtu outside 1500
mtu dmz 1500
arp timeout 14400
route outside 0.0.0.0 0.0.0.0 x.x.x.x
http server enable
http 192.168.1.0 255.255.255.0 inside
http 10.0.0.0 255.0.0.0 dmz
http Remote 255.255.255.0 inside
crypto map outside_map 1 set peer y.y.y.y
encryption des
hash sha
group 2
lifetime 86400
encryption des
hash md5
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection statistics port
threat-detection statistics protocol
webvpn
tunnel-group y.y.y.y type ipsec-l2l
tunnel-group y.y.y.y ipsec-attributes
pre-shared-key *
Correct Answer by drewspot about 5 years 5 months ago
Didn't notice any route statements in the 8.2(5) config. Check your routing with a show route command?
Correct Answer by Marvin Rhoads about 5 years 5 months ago
I notice your non-working configuration has:
...and the working one does not.
Also, when you initiate from the 8.2(5) side, what is your source address?
Correct Answer by Julio Carvajal about 5 years 5 months ago
Hello Tarek,
The configuration looks good to me but here is the thing:
I can see that you have the ip address on one site assigned via PPOE, you should use a dynamic crypto map for this, as the other site does not know wich will be your permanent ip address.
Julio
Overall Rating: 5 (3 ratings)
Correct Answer
Julio Carvajal Sat, 02/18/2012 - 18:57
  • Purple, 4500 points or more
Hello Tarek,
Julio
Tarekeid1_2 Sun, 02/19/2012 - 05:24
Thanks for your suggestion, but I'm getting assigned a permanent real IP through the ISP on ppoe connection and the other site can initiate the tunnel the issue is that the ASA with ppoe and version 8.2(5) is not detecting 192.168.1.0 traffic from inbound interface as vpn traffic although I made sure that the "enable inbound ipsec sessions to bypass interface access lists" check box is checked in site-to-site wizard and that nat traversal is enabled and I already have another site with a ppoe assigned IP and its working fine.
On both sides when I ping the internal ip of the other side from inside I get :
Routing failed to locate next hop for icmp from NP Identity Ifc:192.168.1.101/0 to inside:192.168.10.1/0
I noticed that cisco changed some options and features in version 8.2(5) and the DfltGrpPolicy isn’t shown in the group policy field in asdm though its assigned when I click on the edit section on the site-to-site connection , I’m not sure if this can have an effect on the tunnel though I didn’t change anything in its settings ?
Tarekeid1_2 Sun, 02/19/2012 - 06:36
Ok I've captured the commands sent by both ASA versions and they are identical so I guess Its something related to ASA 8.2(5) defualt settings , I followed Cisco's Most Common L2L and Remote Access IPsec VPN Troubleshooting Solutions but still no luck
  •       access-list outside_1_cryptomap line 1 extended permit ip 192.168.10.0 255.255.255.0 192.168.1.0 255.255.255.0
            pre-shared-key **********
            isakmp keepalive threshold 10 retry 2
  •       access-list outside_1_cryptomap line 1 extended permit ip 192.168.1.0 255.255.255.0 192.168.10.0 255.255.255.0
Correct Answer
Marvin Rhoads Sun, 02/19/2012 - 07:21
  • Cisco Designated VIP,
    2017 Firewalling, Network Management, VPN
Correct Answer
drewspot Sun, 02/19/2012 - 08:45
Tarekeid1_2 Sun, 02/19/2012 - 09:07
yeh I’m getting assigned the default route through the ISPs dhcp “ip address pppoe setroute ” and I have access to internet through the firewall
Tarekeid1_2 Sun, 02/19/2012 - 09:11
And thanks for your suggestion Marvin, but I double checked and I didn’t copy the interface part of configuration of the second ASA so it’s also assigned to vlan2 which is the outside vlan
But I guess it is related to internal interface since I changed the IP of internal interface and packet traced using the old internal IP 192.168.10.1 from inside to the other ASA internal IP 192.168.1.1 and the tunnel came up successfully
That is I configured the internal network of ASA 8.2(5) to 7.7.7.0 and added networks 192.168.10.0 and 7.7.7.0 as inside networks in site-to-site vpn configuration
  • When I packet trace with source 192.168.10.1 (configured on vpn as internal but not assigned to inside vlan1) to destination 192.168.1.1 (internal ip of ASA 8.2(1)) the tunnel comes up
  • When I packet trace with source 7.7.7.7 1 (configured on vpn as internal and assigned to inside vlan1) to destination 192.168.1.1 the tunnel doesn’t initiate and packet gets dropped
I’ve added command management-access inside which unlike older ASA versions it wasn’t enabled but still it didn’t work
Tarekeid1_2 Tue, 02/28/2012 - 13:23
I've solved the issue  last week  and thought I'll post how I solved it so I can close the thread
the symptoms I was having was similar to the ones listed in this document PIX/ASA 7.2(1) and later: Intra-Interface Communications anyway there isn't much difference between the 2 ASA versions I listed, other than that version 8.5(2) did't have the management-access inside command , I've also double checked and corrected the NAT settings for the 7.x.x.x subnet that I created for testing and that eventually got the tunnel working again.
Thank you all for your help and suggestions
Related Content
