Remote Destination Time Zone Setting
Chris Deren Sun, 02/19/2012 - 07:50
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
What version of CUCM do you have?  There should be a time-zone setting under the schedule configuration, it is there in 8.5 for sure.
Chris
I am using version 8.6.2a and also 8.5.1.
Yes there is a timezone setting under schedule configuration but its only for specifying the timezone and periods that this partition is on.
I have tried to set the phone DN with a time schedule with timezone setting and configure RDP for it, but it does not work at all.
Any advise?
Chris Deren Mon, 02/20/2012 - 06:50
  • Hall of Fame,
The partion can be configured to be aware of timezone of originating device when assigning the time schedule.
HTH,
Chris
Yes I knew the partition can be configured with time schedule timezone. I believe you have misunderstood from my question.
My objective is to enable auto select the timezone setting when end user configures their Alternate numbers on the CCM User webpage.
Currently, it is always pointing to Etc/GMT setting.
Anyway to make it default to the user device pool Date Time Group zone?
Chris Deren Mon, 02/20/2012 - 07:18
  • Hall of Fame,
My apologies, I did indeed misunderstood.  I am not aware of any way to make that default change, sorry.
Chris
