Routing with Static-NAT-Mappings
Feb 19th, 2012
  we are using a Cisco 5510 with three networks connected - inside, outside, wlan.  We assigned several port-mappings between the external network and internal servers.  These external addresses are not reachable from the wlan and internal hosts. All internal dun WLAN traffic is NATed thru the outside interface.
  All the traffic gets routed thru our service-provider.
  Here the lines from the config I think might be relevant.
  Please give us any pointers how to fix our problem.
  Fabian
ASA Version 7.0(7)
interface Ethernet0/0.6
vlan 6
nameif airport
security-level 30
no ip address
interface Ethernet0/0.7
vlan 7
nameif outside
security-level 0
ip address 11.11.11.170 255.255.255.0
interface Ethernet0/1
nameif inside
security-level 100
ip address 10.10.10.130 255.255.255.0
dns domain-lookup outside
dns domain-lookup inside
same-security-traffic permit intra-interface
access-list 101 extended permit ip 10.10.10.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list policy_nat_imapssl1 extended permit ip host 10.10.10.158 any
access-list policy_nat_imapssl2 extended permit ip host 10.10.10.158 any
access-list policy_nat_www3 extended permit ip host 10.10.10.247 any
access-list inbound_outside extended permit tcp 11.11.11.0 255.255.255.0 host 11.11.11.212 eq 993
access-list inbound_outside extended permit tcp any host 11.11.11.212 eq 993
access-list inbound_outside extended permit tcp any host 11.11.11.214 eq https
access-list inbound_outside extended permit tcp any host 11.11.11.215 eq www
access-list inbound_outside extended permit tcp any host 11.11.11.215 eq https
access-list inbound_outside extended permit tcp any host 11.11.11.216 eq 9080
access-list inbound_outside extended permit tcp any host 11.11.11.217 eq https
access-list inbound_outside extended permit tcp any host 11.11.11.217 eq www
access-list inbound_outside extended permit tcp any host 11.11.11.243 eq https
access-list inbound_outside extended permit tcp any host 11.11.11.243 eq www
access-list inbound_outside extended permit tcp any host 11.11.11.219 eq 8080
access-list inbound_outside extended permit tcp any host 11.11.11.218 eq 8080
access-list inbound_outside extended permit tcp any host 11.11.11.120 eq 8080
access-list policy_nat_www4 extended permit ip host 10.10.10.180 any
access-list policy_nat_sirius extended permit ip host 10.10.10.238 any
access-list policy_nat_ariel extended permit ip host 10.10.10.218 any
access-list policy_nat_ariel2 extended permit ip host 10.10.10.219 any
nat-control
global (outside) 1 11.11.11.190
nat (inside) 0 access-list 101
static (inside,outside) 11.11.11.212  access-list policy_nat_imapssl1
static (inside,outside) 10.10.10.158  access-list policy_nat_imapssl2
static (inside,outside) 11.11.11.215  access-list policy_nat_www3
static (inside,outside) 11.11.11.211  access-list policy_nat_www4
static (inside,outside) 11.11.11.216  access-list policy_nat_sirius
static (inside,outside) 11.11.11.217  access-list policy_nat_ariel
static (inside,outside) 11.11.11.243  access-list policy_nat_ariel2
access-group inbound_outside in interface outside
route outside 0.0.0.0 0.0.0.0 11.11.11.171 1
no vpn-addr-assign aaa
no vpn-addr-assign dhcp
service-policy global_policy global
