Simple question. Hard to find an answer. Threshold setting on WVC2300
Answered Question
Feb 19th, 2012
Hello
I have a WVC2300
What is the most sensitived setting, a plus or a minus - ???
Come on Cisco, update your documentation!
Correct Answer by mpyhala about 5 years 2 months ago
Hi Clifford,
Thank you for posting. It has been a long time since I played with those settings but if I remember correctly the - side means more sensitivity. Also, I found the following in the WVC210 Admin Guide which appears to confirm this:
Adjust the sensitivity of each window by using the threshold slider (less threshold
means more sensitivity)
Overall Rating: 5 (1 ratings)
Correct Answer
mpyhala Mon, 02/20/2012 - 13:07
  • Gold, 750 points or more
Hi Clifford,
