Activating Multicast on an ASR9k router
Answered Question
Feb 20th, 2012
I need to configure multicast on an ASR9k router  I think I have to download and activate the corresponding .pie file (asr9k-mcast-p-4.1.0) but I do not find this file in cisco.com
The "show install inactive summary" command shows no software packets inactives.
The "show install active summary" shows active only the asr9k-mini-p-4.1.0 packet.
Could anyone upload the file or paste the link  to download the .pie file for activating multicast routing on ASR9K platform?
Thank you in advance.
Correct Answer by Vadim Zhovtanyuk about 5 years 5 months ago
Hi  marhifer2003
You need to download the tar file which contain the multicast pie
http://www.cisco.com/cisco/software/release.html?mdfid=282423206&flowid=2138&softwareid=280805694&release=4.2.0&relind=AVAILABLE&rellifecycle=&reltype=latest
There is no separate multicast pie file on CCO
Then you can untar it find the multicast pie and add/activate it on your router.
vadim
Overall Rating: 5 (1 ratings)
Correct Answer
Vadim Zhovtanyuk Mon, 02/20/2012 - 02:47
  • Cisco Employee,
Hi  marhifer2003
vadim
marhifer2003 Mon, 02/20/2012 - 03:15
Vadim, thank you very much for your answer.
I can not download the file.... It seems I have no rights to download this file.... Is there any other way to obtain this file?
Vadim Zhovtanyuk Mon, 02/20/2012 - 04:53
  • Cisco Employee,
you can open a TAC case and ask for the assistance with downloading the file.
The other way is to publish the multicast pie for you.
To we need to know your CCO user id.
If you can let me know about your CCO user id I can publish the multicast pie for you on CCO in
publishing seciton.
vadim
marhifer2003 Thu, 02/23/2012 - 23:04
Could anyone publish the mcast.pie file (version 4.1.2) for me, please?
Vadim Zhovtanyuk Fri, 02/24/2012 - 05:37
  • Cisco Employee,
Hi Marcos,
Sorry for delay I'm out of the office now,
I will reply to you in private discussion in few minutes
wbr
/vadim
marhifer2003 Fri, 02/24/2012 - 10:48
Thank you Vadim
You have saved my life!!
Sorry for the inconvenience.
