Byte-level & Object cache
Feb 20th, 2012
Hello -
I was wondering if it's possible to view this information via the CM or CLI on a connection basis and overall?
The WAAS does both byte-level and object cache storing, correct?
John
johng231 Mon, 03/26/2012 - 07:37
Can anyone confirm if the WAAS does both byte level and object level caching? If so, is it possible to view this information.
pevaneyn Wed, 03/28/2012 - 08:35
  • Cisco Employee,
The WAAS has two caches:
- CIFS cache which caches CIFS 'objects'.
  With special scripts it is possible to view information regarding these objects. Not from the normal CLI.
- DRE cache which caches data transfered, regardless of the method used.
  It is not possible to see information in the DRE cache from the CLI, nor can I see how a script would help you.
Peter
