ISDN BRI Causes
Feb 20th, 2012
I have problem with sending causes (User busy, Unallocated/unassigned number) to PSTN via ISDN BRI interface.
In IOS 12.4 gateway 2811 sends:
Feb 20 17:41:25.259 MET: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x98E8
       Cause i = 0x8081 - Unallocated/unassigned number
In IOS 15 gateway 2911 sends:
Feb 20 16:47:29.230: ISDN BR0/2/1 Q931: TX -> PROGRESS pd = 8 callref = 0x8B
       Cause i = 0x8181 - Unallocated/unassigned number
       Progress Ind i = 0x8188 - In-band info or appropriate now available
I have problem with this behavior, because my telephony provider doesn't accept causes in PI, so calling party hear only silence. Is it possible change behavior of 2911 gateway for sending DISCONNECT and Cause instead PROGRESS and Cause.
Thank you,
Jaroslav
paolo bevilacqua Tue, 02/21/2012 - 05:54
  • Hall of Fame,
    Founding Member
Can you include relevant configuration ?
jaroslav.srytr Tue, 02/21/2012 - 06:16
there is configuration. My problem is, that if gateway (2911) receive SETUP message to unallocated number, it sends this information is PROGRESS messages but I need DISCONNECT message.
version 15.1
service password-encryption
hostname Router_20
boot-start-marker
boot system flash c2900-universalk9-mz.SPA.151-3.T2.bin
boot-end-marker
logging buffered 32000
enable secret XXX
no aaa new-model
network-clock-participate wic 0
no ipv6 cef
no ip source-route
ip cef
no ip domain lookup
ip domain name yourdomain.com
isdn switch-type basic-net3
voice-card 0
license udi pid CISCO2911/K9 sn XXX
hw-module pvdm 0/0
hw-module pvdm 0/1
hw-module sm 1
redundancy
interface GigabitEthernet0/0
ip address X.X.X.X X.X.X.X
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface BRI0/2/0
no ip address
isdn point-to-point-setup
isdn incoming-voice voice
isdn sending-complete
isdn static-tei 0
interface BRI0/2/1
no ip address
isdn static-tei 0
interface SM1/1
shutdown
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
voice-port 0/0/0
compand-type a-law
cptone CZ
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/2/0
compand-type a-law
cptone CZ
voice-port 0/2/1
compand-type a-law
cptone CZ
mgcp profile default
dial-peer voice 100 pots
description <----- Outgoing call to ISDN (PSTN)
destination-pattern 0T
port 0/2/0
dial-peer voice 101 pots
description <----- Incomming call from ISDN (PSTN)
incoming called-number .
direct-inward-dial
dial-peer voice 200 pots
huntstop
destination-pattern 482428137$
port 0/0/0
gatekeeper
shutdown
line con 0
logging synchronous
line aux 0
line vty 0 4
password XxX
logging synchronous
login
transport input telnet ssh
scheduler allocate 20000 1000
end
paolo bevilacqua Tue, 02/21/2012 - 09:05
  • Hall of Fame,
    Founding Member
Is this for CME, or CUCME ? if the latter, where's the voip DP config ?
jaroslav.srytr Tue, 02/21/2012 - 09:46
This isn’t CUCM or CME. GW has one ISDN card (2 ports) and one FXS card (4 ports). One port of ISDN card is connected to the PSTN (telephony provider) and FXS card has connected analog phones. If GW received SETUP message from PSTN to number, which isn’t allocated, GW sends PROGRESS message with “Unallocated/unassigned number” cause to the PSTN. But I need send DISCONNECT message to the PSTN (as on 2800 ISR).
Dial-peers:
DP 100 – Outgoing DP to the PSTN
DP 101 – Incomming DP from PSTN (with direct-inward dial option)
DP 200 – Analog phone connected to the FXS card
paolo bevilacqua Wed, 02/22/2012 - 00:59
  • Hall of Fame,
    Founding Member
It should be the default, but can you try
conf t
no voice call convert-discpi-to-prog
And, can you specify the exact IOS are you using.
Anyway I think the problem should not be a major one, because I don't see a reason why people should be calling your unallocated numbers .
Amit Sharma Tue, 02/21/2012 - 09:06
  • Cisco Employee,
seems like some kind of announcement being played out.
please try removing any annuniciators if any in the call flow.
try changing the isdn switch type and check
Though does not seem tiyou may also try the following comand :
paolo bevilacqua Tue, 02/21/2012 - 09:14
  • Hall of Fame,
    Founding Member
Amit Sharma wrote:
Why on earth should the switch type being changed when is correct ?
What annunciator are yout taling about ??
Do you understand the OP problem ???
Kevin Monteiro Wed, 02/22/2012 - 23:02
  • Silver, 250 points or more
Thankyou Amit for indentifying the issue in One (1) Go.I had a  similar issue which was rectified by this same resolution.
Thankyou jaroslav for checking your configuration where the TCL/IVR SCRIPT which was in the call flow. Making it relevent and sensible.
Appreciate everyone's view.
Kevin Monteiro Tue, 02/21/2012 - 23:18
can you please show the call flow and the show run of the  of the existing 2811 where its working fine.
jaroslav.srytr Wed, 02/22/2012 - 01:09
I’m sorry for this topic. Problem isn’t in ISRG2, but in TCL application, which is in call path. If I stopped it, ISR and ISRG2 have same (correct) behavour.
paolo bevilacqua Wed, 02/22/2012 - 01:24
  • Hall of Fame,
    Founding Member
Thanks for the clarification. Noticeably, no application configuration was present in the config you sent before.
Anyway, it should be possible to code the TCL/IVR script to behave as desired.
Please remember to rate useful posts clicking on the stars below.
Kevin Monteiro Wed, 02/22/2012 - 08:21
No issues jaroslav. we are always there to help  you out !!! .. Amit you were right here..... Kudos!!!
Related Content
