Warning message
ICM Purge Error....
Feb 17th, 2012
The Issue occures the Recovery (rcv) process on the Database Server and the
Replication (rpl) process on the HDS.
AutoPurge fuction run 00:30 a.m but  this issue happend.
so There are insert to data not deleted contiually.
Check out below to information.
1.  fail to PurgeTCD job scheduler on Logger side A continually.
2.  fail to PurgeTCD and PurgeRCD job scheduler on Logger side B contiually.
3. success to job scheduler on AWS but  not delete data.
The issue seems to be that concering to recoverykey.
Look at the attatched files(nm,hjlg,rcv,rpl, ICMDBA used summary report, SQL errorlog etc.)
[Version Information]
ICM 8.5.1
Please technical help me.
Thanks.
david.macias Fri, 02/17/2012 - 05:28
  • Blue, 1500 points or more
Instead of posting screenshots can you post actual logs?
david
spaulin Fri, 02/17/2012 - 16:20
  • Bronze, 100 points or more
Indeed, you'll really want to open a TAC Service Request for this.
You'll want to provide them with the following logs:
From the Logger:  NM, HLGR, RCV, RPL
From the AW/HDS:  NM, RPL
Please also include exports of the ICMDBA Space Used Summary Report (.csv file), and the SQL Server Errorlog.
Omar Deen Tue, 03/18/2014 - 12:01
  • Silver, 250 points or more
What is your exact issue?
Related Content
