Unable to login to UC320
Answered Question
Feb 20th, 2012
Using Firefox 3.6 on Windows 7
All I get is the Cisco banner and a green line, the tab says "Cisco UC320W Firmware Upgrade"
No Login Prompt at all!
Correct Answer by David Harper about 5 years 4 months ago
It's not the Flash 11 problem is it?  Check
https://supportforums.cisco.com/message/3478189
for details.
Cheers,
Dave.
Overall Rating: 5 (1 ratings)
barnesc64 Tue, 02/21/2012 - 05:15
Thanks Dave, that was the problem. I used the online cloud upgrade method to update the device, all worked perfectly.
David Harper Tue, 02/21/2012 - 17:01
  • Cisco Employee,
Cool.  Glad you are all sorted.
Cheers,
Dave.
