Warning message
Ryan Curry Tue, 02/21/2012 - 07:45
Are you asking how many ports are allowed in a port channel?  If so, 8 is the max and they must all be of the same type (speed, duplex, etc.) and configuration (i.e. trunk or access as well as allowed VLANs).  Hope that helps.
vmiller Tue, 02/21/2012 - 07:54
  • Gold, 750 points or more
For IOS12.2.18 you can create a maximum of 128 etherchannels, subject to the constraints listed above.
For CATos  I bleieve ther is a limitation in some chassis to 63.
Ryan Curry Tue, 02/21/2012 - 08:26
Well, there you go, it's not the first time I've been wrong ...
viswamin Tue, 02/21/2012 - 08:33
  • Cisco Employee,
I think vmiller was talking about No. of EtherChannels and you were talking about No. of ports in an Etherchannel... Both are different and you were not wrong AFAIK.
-Vijay
Jovan Bogoev Thu, 11/08/2012 - 18:10
Beware of trying to port-channel interfaces across different line cards. The QoS scheduling can be different and not allow a port-channel to come up. See the difference below:
sh int te7/12 cap
TenGigabitEthernet7/12
  Model:                 WS-X6716-10GE
  Type:                  10Gbase-SR
  Speed:                 10000
  Duplex:                full
  Trunk encap. type:     802.1Q
  Trunk mode:            on,off,desirable,nonegotiate
  Channel:               yes
  Broadcast suppression: percentage(0-100)
  Flowcontrol:           rx-(off,on),tx-(off,on)
  Membership:            static
  Fast Start:            yes
  QOS scheduling:        rx-(1p7q2t), tx-(1p7q4t)
  QOS queueing mode:     rx-(cos,dscp), tx-(cos,dscp)
  CoS rewrite:           yes
  ToS rewrite:           yes
  Inline power:          no
  Inline power policing: no
  SPAN:                  source/destination
  UDLD                   yes
  Link Debounce:         yes
  Link Debounce Time:    yes
  Ports-in-ASIC (Sub-port ASIC) : 9-16 (9-12)
  Remote switch uplink:  no
  Dot1x:                 yes
  Port-Security:         yes
sh int te6/1 cap
TenGigabitEthernet6/1
  Model:                 WS-X6708-10GE
  Type:                  10Gbase-SR
  Speed:                 10000
  Duplex:                full
  Trunk encap. type:     802.1Q,ISL
  Channel:               yes
  Membership:            static
  Fast Start:            yes
QOS scheduling:        rx-(8q4t), tx-(1p7q4t)
  CoS rewrite:           yes
  ToS rewrite:           yes
  Inline power:          no
  UDLD                   yes
  Link Debounce:         yes
  Ports-in-ASIC (Sub-port ASIC) : 1,4-5,7 (1)
  Dot1x:                 yes
  Port-Security:         yes
This is the error you will see:
%EC-SP-5-CANNOT_BUNDLE2: Te7/12 is not compatible with Te6/1 and will be suspended (qos-card types of Te7/12 do not match Te6/1)
Enter the command below on the port-channel to allow the grouping of the ports
#no mls qos channel-consistency
That being said I hope I can bundle interfaces of different optic types i.e. 10Gbase-SR and 10Gbase-LRM
