02-20-2012 01:53 PM
Hi All
when i am trying to install Waas Network module NME-WAE-502-K9 at 2811 router i face a problem when trying to open a session on thr integrated service module as it takes too long time trying to open but no use as follows:
Router#service-module integrated-Service-Engine 1/0 session
Trying 10.52.55.253, 2066 ... Open
also i found that the status of the integrated service module is not stable as follows:
first
Router#service-module integrated-Service-Engine 1/0 status
Service Module is Cisco Integrated-Service-Engine1/0
Service Module supports session via TTY line 66
Service Module is trying to recover from error
Service Module heartbeat-reset is enabled
Service Module is in fail open
Service Module status is not available
second i applied reset by :
Router#service-module integrated-Service-Engine 1/0 reset
Use reset only to recover from shutdown or failed state
Warning: May lose data on the hard disc!
Do you want to reset?[confirm]
Trying to reset Service Module Integrated-Service-Engine1/0.
third got the following status
Service Module is waiting for registration message
fourth it appears that:
Router#
Trying to shutdown Service Module Integrated-Service-Engine1/0
And finally i got this status
my router config is :
interface FastEthernet0/0
ip address 172.23.55.5 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface Integrated-Service-Engine1/0
ip address 10.52.55.253 255.255.255.252
service-module ip address 10.52.55.254 255.255.255.252
service-module ip default-gateway 10.52.55.253
no keepalive
ip forward-protocol nd
ip route 10.52.55.254 255.255.255.255 Integrated-Service-Engine1/0
no ip http server
no ip http secure-server
please help me with that
Mohammad Hamed
10-28-2013 10:33 PM
I have same problem. I shutdown the module and reset it, it works.
02-03-2014 03:43 AM
can somebody advice the impact of "no keepalive " here ?
If i use keepalive command instead of "no keepalive " what would be the impact ?
