CME 9.0 and SPA telephones
Feb 21st, 2012
Hi!
I have discovered, that there are no SPA telephones under the "load" command in "Telephony-service" section.
There are only 6xxx and 7xxx types.
Is there any way to configure SPA telephones in CME 9.0? Or this is only IOS question?
Aleksei
Average Rating: 5 (2 ratings)
Aleksei.Zjabkin Tue, 02/21/2012 - 23:45
Hmm. I have UC 540 with CME 8.0.
I have found the spa phones under the load command on UC540.
And there are no SPA phones in documentation for CME 8.0 also.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme80spc.htm
So I think there is some other reason.
By the way, how can I configure SPA telephone, which requires configuration and firmware from the CME, if consider that SPA is now third party?
Brandon Svec Wed, 02/22/2012 - 11:01
SPA phones use SPCP protocol.  It is like a crippled version of SCCP/skinny.  Presumably, Cisco wants these cheaper phones only to work on UC3XX and UC5XX systems and encourage you to buy more expensive phones for CME and CM..
However as other posters said, you can flash them with SIP firmware and then treat them as third party SIP phones.
However, as third party SIP you should expect some feature deficiencies compared to supported phones.
Login or Register to take actions
Posted February 21, 2012 at 11:26 PM
Stats:
Replies:6 Avg. Rating:5
Views:758 Votes:0
Shares:0
Tags: No tags.
Discussions Leaderboard
Rank Username Points
1 21,036
2 15,047
3 10,325
4 8,014
5 4,856
121
105
98
62
61
