Warning message
Cisco 1841 VPN static route - help
Feb 22nd, 2012
Hi all,
I need little help with VPN 1841, and static nat. I have to create VPN to connect to remote network, but problem is that they already use same subnet as mine. How to configure static nat on cisco 1841 so static nat will work and address will be translated in different IP when connection trough VPN.
I have address 192.168.235.1 and I want to translate to 192.168.100.1
This 1841 is border router, and all VLNAs and VLANs routing is on 3650.
Thanks in advance!
bojan.vujic Wed, 02/22/2012 - 04:30
I forgot to say that I need help just about NAT example, not all VPN configuration. I already have configured several VPN and all works fine, and this is first time that I need t use static nat.
