02-22-2012 05:19 PM
I have to configure the EVC on 7613 with ES+20G.
But i can not configure it because there is no the encapsulation configuration on 7613.
So i check the relese12.2(SR) configuration note and then i know there is the encapsulation configuration on 7613.
I have used the 12.2(33)SRD4 version.
So can you teach me the WHY and HOW to configure it on 7613.
Thank you
02-25-2012 01:51 AM
what do you mean there is no encapsulation on 7613?
The config on 7613 does not differ from any other 7600 router.
The EVC configuration will be something like this:
Interface GigabitEthernetx/x
service instance 15 ethernet
encapsulation dot1q 2000 second-dot1q 20
rewrite ingress tag pop 2 symmetric
bridge-domain 110
service instance 40 ethernet
encapsulation dot1q 333
rewrite ingress tag pop 1 symmetric
bridge-domain 32 split-horizon
for more have a look at:
Cisco 7600 Series Ethernet Services Plus (ES+) and Ethernet Services Plus T (ES+T) Line Card Configuration Guide
Configuring Layer 1 and Layer 2 Features
http://www.cisco.com/en/US/docs/routers/7600/install_config/ES40_config_guide/es40_chap4.html
Riccardo
02-28-2012 03:15 PM
Thank you for your help...
you are very kind
Thank you
