Siemens Arcadis Varic - Wireless connectivity problems
Feb 23rd, 2012
  • Bronze, 100 points or more
Our radiology department has recently recieved a couple of Arcadis Varic devices and so we tried to connect to our network wirelessly, but it constantly failed to connect. The error messages in ACS was "11500 Invalid or unexpected EAP payload recieved"
The device has windows on it but doesn't have a wireless nic, instead it has a wireless converter connected to an internal hub. The device is configured within windows by selecting one of 4 options, the top two are WPA-PSK (Medium) and WPA2 (High). We wen't for 'High' and supplied an ssid, username and password assuming it was AES/PEAP/MSCHAPv2.
I've attached a debug that shows the device associating and trying to authenticate then being excluded.
Has anyone seen this error message before?
Martin
Scott Fella Thu, 02/23/2012 - 04:51
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Let me ask... have you tested with any of the other security methods to see if these devices connect at least?  On this SSID, can you connect successfully with another devices like a laptop to verify that your configuration is correct?  When using "High", What do you see in your radius server logs.  These wireless converters require "Passive Client" to be enabled on the SSID also.
Related Content
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
