Difference between Port Channel and Ether Channel
Answered Question
Feb 23rd, 2012
Hi All,
What is the exact difference between Port-Channel and Ether-Channel. or if they are same terms.
If the below setup is possible. If yes, please let me know the sample config of the L3 and the router1 or any link to the documentation will help.
Also, if the Port channel interface will be l2 or is it possible to configure it l3.
Your reply is higly appreciated.
Ravindra K
Correct Answer by Peter Paluch about 5 years 4 months ago
Perhaps just to add a minor comment: "EtherChannel" or "Link Aggregation" is the particular technology that allows you to bundle several links between two devices and use them simultaneously as a single interface. The "Port-channel" is the name of this virtual interface in IOS. This is similar to, say, WiFi as a technology, and "Dot11Radio0" as the name of the interface, or ISDN as a technology, and BRI as an interface name.
Best regards,
Peter
Overall Rating: 5 (4 ratings)
rsimoni Thu, 02/23/2012 - 03:39
  • Cisco Employee,
Port-channel and ether-channel are synonyms.
The way you configured your channel is wrong (unless R1 and R2 are some kind of logically single router/switch such as N7K vpC or Cat6500 VSS - or for some other corner case scnario).
You need to have 2 or more links from a L2 or L3 device bundled together in a portchannel terminating to a SINGLE router or switch.
Riccardo
ravindra Krishna Thu, 02/23/2012 - 04:04
Hi Riccardo,
So you mean
Port-Channel=Link Aggregation=Link Aggregation?
Ravindra K
mtsb Thu, 02/23/2012 - 04:34
  • Bronze, 100 points or more
Hi Ravindra,
Yes, they are all same. In IOS-XR world, they call it bundle-ether.
Port-channel can be of L2 or L3 depending on how you configure it.
Madhu
rsimoni Thu, 02/23/2012 - 07:57
  • Cisco Employee,
Hi Ravindra,
I guess you meant
Port-Channel=Etherchannel=Link Aggregation?
the answer is yes.
Riccardo
ravindra Krishna Fri, 02/24/2012 - 22:15
yes you are right. I meant
Thanks Ricardo. It's resolved.
Ravi
Correct Answer
Peter Paluch Fri, 02/24/2012 - 14:45
  • Cisco Employee,
Best regards,
Peter
Leo Laohoo Fri, 02/24/2012 - 14:53
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Errr ... Dot11Radio0 and Dot11Radio1 are both physical interface.  Bridged Virtual Interface (BVI) is a virtual interface for both wired and wireless networks.
Peter Paluch Fri, 02/24/2012 - 15:09
  • Cisco Employee,
Leo,
Yes, you're right - I was merely pointing on the difference between a technology and the usual name for the interface to access that technology.
Best regards,
Peter
