Warning message
2801 - Yellow light on 2 vic interf. (4xVIC3-2FXS/DID 2xPVDM2-8)
Feb 23rd, 2012
Hi all,
I´m facing some trouble to get the 2 of the 4 VIC3 running on my 2801. Does anybody has an idear what might be wrong, any suggestions
are really appreciated.
The VIC´s on Slot 2 and 3 aren´t coming up.... It should look like below....but I don´t get any messages at all regarding Slot 2 and 3.
(only 1&2 are coming up)
*Feb 23 14:42:25.543 MET: %LINK-3-UPDOWN: Interface Foreign Exchange Station 0/2/0, changed state to up
*Feb 23 14:42:26.063 MET: %LINK-3-UPDOWN: Interface Foreign Exchange Station 0/2/1, changed state to up
*Feb 23 14:42:26.747 MET: %LINK-3-UPDOWN: Interface Foreign Exchange Station 0/3/0, changed state to up
*Feb 23 14:42:26.747 MET: %LINK-3-UPDOWN: Interface Foreign Exchange Station 0/3/1, changed state to up
Both DSP Lights on the chassis are green. Do I have to install additional DSP Modules on the Mainboard ?
Thanks in advance
Frank
LimoTest#sh ver
Cisco IOS Software, 2801 Software (C2801-IPVOICEK9-M), Version 15.0(1)XA5, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Mon 20-Dec-10 23:55 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
LimoTest uptime is 35 minutes
System returned to ROM by reload at 12:29:09 UTC Thu Feb 23 2012
System image file is "flash:c2801-ipvoicek9-mz.150-1.XA5.bin"
Cisco 2801 (revision 7.0) with 222208K/39936K bytes of memory.
Processor board ID FCZ125113N3
2 FastEthernet interfaces
8 Voice FXS interfaces
2 DSPs, 8 Voice resources
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62720K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2801
LimoTest#sh inve
NAME: "chassis", DESCR: "2801 chassis"
PID: CISCO2801         , VID: V05 , SN: FCZ125113N3
NAME: "VIC 0", DESCR: "3rd generation two port FXS DID voice interface daughtercard"
PID: VIC3-2FXS/DID     , VID: V03 , SN: FOC15515LYP
NAME: "WIC/VIC/HWIC 1", DESCR: "3rd generation two port FXS DID voice interface daughtercard"
PID: VIC3-2FXS/DID     , VID: V03 , SN: FOC15465J3L
NAME: "WIC/VIC 2", DESCR: "3rd generation two port FXS DID voice interface daughtercard"
PID: VIC3-2FXS/DID     , VID: V03 , SN: FOC15250EEA
NAME: "WIC/VIC/HWIC 3", DESCR: "3rd generation two port FXS DID voice interface daughtercard"
PID: VIC3-2FXS/DID     , VID: V03 , SN: FOC15493HG6
NAME: "PVDM 0", DESCR: "PVDMII DSP SIMM with one DSP with half channel capcity"
PID: PVDM2-8           , VID: V01 , SN: FOC12480S7G
NAME: "PVDM 1", DESCR: "PVDMII DSP SIMM with one DSP with half channel capcity"
PID: PVDM2-8           , VID: V01 , SN: FOC15262C1X
LimoTest#sh diag
Slot 0:
        C2801 2FE 4SLOT Mainboard Port adapter, 13 ports
        Port adapter is analyzed
        Port adapter insertion time 00:23:54 ago
        EEPROM contents at hardware discovery:
        Chassis MAC Address      : 0021.a01f.c61c
        MAC Address block size   : 34
        PCB Serial Number        : FOC1248108G
        Hardware Revision        : 7.0
        Part Number              : 73-8190-08
        Board Revision           : A0
        Top Assy. Part Number    : 800-23435-06
        Deviation Number         : 0
        Fab Version              : 04
        CLEI Code                : IPMK400ARA
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Product (FRU) Number     : CISCO2801
        Version Identifier       : V05
        Processor type           : 86
        Chassis Serial Number    : FCZ125113N3
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C3 06 00 21 A0 1F C6 1C 43 00 22 C1 8B 46
          0x10: 4F 43 31 32 34 38 31 30 38 47 40 04 1C 41 07 00
          0x20: 82 49 1F FE 08 42 41 30 C0 46 03 20 00 5B 8B 06
          0x30: 88 00 00 00 00 02 04 C6 8A 49 50 4D 4B 34 30 30
          0x40: 41 52 41 03 00 81 00 00 00 00 04 00 CB 89 43 49
          0x50: 53 43 4F 32 38 30 31 89 56 30 35 20 D9 02 C1 40
          0x60: 09 86 C2 8B 46 43 5A 31 32 35 31 31 33 4E 33 FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x90: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xB0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xD0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x100: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x110: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x120: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x130: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x140: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x150: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x160: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x170: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x180: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x190: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x1A0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x1B0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x1C0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x1D0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x1E0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x1F0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        PVDM Slot 0:
        8-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
        Hardware Revision        : 4.0
        Part Number              : 73-8848-05
        Board Revision           : C0
        Fab Version              : 04
        PCB Serial Number        : FOC12480S7G
        RMA History              : 00
        Processor type           : 00
        Product (FRU) Number     : PVDM2-8
        Version Identifier       : V01
          0x00: 04 FF 40 04 30 41 04 00 82 49 22 90 05 42 43 30
          0x10: 88 00 00 00 00 02 04 C1 8B 46 4F 43 31 32 34 38
          0x20: 30 53 37 47 03 00 81 00 00 00 00 04 00 09 00 CB
          0x30: 88 50 56 44 4D 32 2D 38 20 89 56 30 31 20 D9 02
          0x40: 40 C1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        PVDM Slot 1:
        Board Revision           : C0
        Fab Version              : 04
        PCB Serial Number        : FOC15262C1X
        RMA History              : 00
        Processor type           : 00
          0x10: 88 00 00 00 00 02 04 C1 8B 46 4F 43 31 35 32 36
          0x20: 32 43 31 58 03 00 81 00 00 00 00 04 00 09 00 CB
        VIC Slot 0:
        3rd generation - FXS DID Voice daughter card (2 port)
        Hardware Revision        : 1.0
        Top Assy. Part Number    : 800-33587-01
        Board Revision           : D0
        Fab Version              : 08
        PCB Serial Number        : FOC15515LYP
        RMA History              : 00
        Product (FRU) Number     : VIC3-2FXS/DID
        Version Identifier       : V03
        CLEI Code                : IP9IAB3CAC
        Longitudinal Calibration : 01 10 10 72 7F 10 10 6C
                                   8D
          0x00: 04 FF 40 06 21 41 01 00 C0 46 03 20 00 83 33 01
          0x10: 42 44 30 88 00 00 00 00 02 08 C1 8B 46 4F 43 31
          0x20: 35 35 31 35 4C 59 50 03 00 81 00 00 00 00 04 00
          0x30: CB 8D 56 49 43 33 2D 32 46 58 53 2F 44 49 44 89
          0x40: 56 30 33 20 D9 02 40 C1 C6 8A 49 50 39 49 41 42
          0x50: 33 43 41 43 D3 09 01 10 10 72 7F 10 10 6C 8D FF
        WIC/VIC/HWIC Slot 1:
        Board Revision           : D0
        Fab Version              : 08
        PCB Serial Number        : FOC15465J3L
        RMA History              : 00
        Longitudinal Calibration : 01 10 10 40 82 10 10 97
                                   48
          0x20: 35 34 36 35 4A 33 4C 03 00 81 00 00 00 00 04 00
          0x50: 33 43 41 43 D3 09 01 10 10 40 82 10 10 97 48 FF
        WIC/VIC Slot 2:
        Board Revision           : D0
        Fab Version              : 08
        PCB Serial Number        : FOC15250EEA
        RMA History              : 00
        Longitudinal Calibration : 01 10 10 9B A6 10 10 88
                                   6B
          0x20: 35 32 35 30 45 45 41 03 00 81 00 00 00 00 04 00
          0x50: 33 43 41 43 D3 09 01 10 10 9B A6 10 10 88 6B FF
        WIC/VIC/HWIC Slot 3:
        Board Revision           : D0
        Fab Version              : 08
        PCB Serial Number        : FOC15493HG6
        RMA History              : 00
        Longitudinal Calibration : 01 10 10 82 62 10 10 91
                                   68
          0x20: 35 34 39 33 48 47 36 03 00 81 00 00 00 00 04 00
          0x50: 33 43 41 43 D3 09 01 10 10 82 62 10 10 91 68 FF
*Feb 23 13:41:55.179: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0, changed state to up
*Feb 23 13:41:56.711: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, changed state to down
*Feb 23 13:41:57.311: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/1, changed state to up
*Feb 23 14:41:57.411 MET: %SYS-6-CLOCKUPDATE: System clock has been updated from 13:41:57 UTC Thu Feb 23 2012 to 14:41:57 MET Thu Feb 23 2012, configured from console by console.
*Feb 23 14:41:57.415 MET: %SYS-6-CLOCKUPDATE: System clock has been updated from 14:41:57 MET Thu Feb 23 2012 to 14:41:57 MET Thu Feb 23 2012, configured from console by console.
*Feb 23 14:42:11.695 MET: CEF-HWIDB: EDSP0 LES switching vector set to Null
*Feb 23 14:42:11.695 MET: CEF-HWIDB: EDSP0 LES switching vector set to CEF switching
*Feb 23 14:42:11.699 MET: %EDSP-6-IPV6_ENABLED: IPv6 on interface EDSP0 added.
*Feb 23 14:42:11.827 MET: %EDSP-6-IPV6_ENABLED: IPv6 on interface EDSP0.1 added.
*Feb 23 14:42:11.831 MET: %EDSP-6-IPV6_ENABLED: IPv6 on interface EDSP0.2 added.
*Feb 23 14:42:11.835 MET: %EDSP-6-IPV6_ENABLED: IPv6 on interface EDSP0.3 added.
*Feb 23 14:42:11.835 MET: %EDSP-6-IPV6_ENABLED: IPv6 on interface EDSP0.4 added.
*Feb 23 14:42:11.839 MET: %EDSP-6-IPV6_ENABLED: IPv6 on interface EDSP0.5 added.
*Feb 23 14:42:11.891 MET: %SYS-5-CONFIG_I: Configured from memory by console
*Feb 23 14:42:12.683 MET: %SYS-5-RESTART: System restarted --
*Feb 23 14:42:12.695 MET: %SNMP-5-COLDSTART: SNMP agent on host LimoTest is undergoing a cold start
*Feb 23 14:42:13.023 MET: %SSH-5-ENABLED: SSH 1.99 has been enabled
*Feb 23 14:42:13.027 MET: %LINEPROTO-5-UPDOWN: Line protocol on Interface EDSP0, changed state to up
*Feb 23 14:42:13.111 MET: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 172.21.21.92 port 514 started - CLI initiated
*Feb 23 14:42:13.511 MET: %LINK-3-UPDOWN: Interface FastEthernet0/0, changed state to up
*Feb 23 14:42:14.519 MET: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, changed state to up
*Feb 23 14:42:16.071 MET: %DSPRM-5-UPDOWN: DSP 1 in slot 0, changed state to up
*Feb 23 14:42:16.387 MET: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, changed state to down
*Feb 23 14:42:17.723 MET: %DSPRM-5-UPDOWN: DSP 5 in slot 0, changed state to up
*Feb 23 14:42:25.543 MET: %LINK-3-UPDOWN: Interface Foreign Exchange Station 0/0/0, changed state to up
*Feb 23 14:42:26.063 MET: %LINK-3-UPDOWN: Interface Foreign Exchange Station 0/0/1, changed state to up
*Feb 23 14:42:26.747 MET: %LINK-3-UPDOWN: Interface Foreign Exchange Station 0/1/0, changed state to up
*Feb 23 14:42:26.747 MET: %LINK-3-UPDOWN: Interface Foreign Exchange Station 0/1/1, changed state to up
