Polycom analog feature codes
Feb 23rd, 2012
We migrated from a Nortel PBX to Cisco CM with our Polycom analog phones connected to VG224s. However the codes we would use to transfer, conference, etc. no longer work. Assuming that our VG224 is configured correctly, is there a list of feature codes that I can use to see if these features are already programmed but I'm just using the wrong codes?
In other words, I need to know what keys to press on our SoundStation to transfer, conference, etc.
Chris Deren Thu, 02/23/2012 - 09:12
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
What protocol are you using to control the analog ports on VG224?
Supplementary codes are only supported with SCCP protocol, so MGCP/H323/SIP will not work with those.
HTH,
Chris
anthony.smith Mon, 03/12/2012 - 09:39
It looks like we've got this figured out. When our system was installed the 'Multiple Call/Call Waiting Settings' for analog lines on the Directory Number Configuration page was not set correctly. The 'Maximum Number of Calls' and 'Busy Trigger' both need to be set to '2' in order for our feature codes to work. They were originally set to '1'.
Thanks for your responses.
