UCCX7 with 3rd ASR
Feb 23rd, 2012
I'm trying to test UCCX7.0.1SR5 with the 3rd party ASR(not in the cisco compatibility list) that support MRCPv1
Speech Recognition engine can regconize the word and return message to UCCX but UCCX cannot find the returned tag.
Returned Message from 3rd Party MRCP Server is here below.
RECOGNITION-COMPLETE 101 COMPLETE MRCP/1.0
Completion-Cause: 000 success
Content-Type: application/x-nlsml
Content-Length: 242
<?xml version="1.0" encoding="UTF-8"?>
<result>
<interpretation grammar="session:[email protected]" confidence="94">
  <input mode="speech"></input>
  <instance>tag one</instance>
</interpretation>
</result>
And in the UCCX ASR Log file is here below
9432: Feb 23 17:55:03.503 ICT %MIVR-SS_MRCP_ASR-7-UNK:SimpleRecognitionDialogImpl(Channel id:0, Contact id:11, Task id:22000000012):DialogObjectDTMF:Rec Results from playAndRecognize():
Result[
    Number of Interpretations = 1
        Interpretation[
            confidence =90
            grammar=session:[email protected]
            Input[
                text=<tag one>
                mode=speech
                confidence=<not set>
                noinput=false
                nomatch=false
            Number of Instances = 1
                Instance[
9433: Feb 23 17:55:03.503 ICT %MIVR-SS_MRCP_ASR-7-UNK:SimpleRecognitionDialogImpl(Channel id:0, Contact id:11, Task id:22000000012):processInterpretation() - the result does not contain the specified tag name: tag
The tag format that I'm using look like this
<tag><![CDATA[<tag one>]]></tag>
From the error I think 3rd Party MRCP doesn't send the appropriate message that UCCX can understand.
So, where I can find the correct returned message that UCCX can understand. The document for UCCX doesn't has much detail for this topic
Regard,
Tinnakorn
prashraj Thu, 02/23/2012 - 11:53
Yes if this is not in our compatibility guide, you will have to order something from our compatible list of ASR"S
Please see below:
Scansoft/Nuance:
SpeechWorks Media Server 3.1.6 or 3.1.9
Open Speech Recognition Server 3.0.4 or 3.0.9
RealSpeak 4.0.6 or 4.0.10
Nuance 8.5:
MRCP Server 1.0 SP 9 or 1.0 SP 10 or 1-0-0-SP12
Speech Recognition 8.5, SP050513 or 8.5, SP050930
Vocalizer 4.0.4 or 4.0.5 or 4.0.6
IBM WebSphere Voice Server:
MRCP Server - MRCP Server 1.0
ASR – WebSphere Voice Server V5.1.3
TTS – CTTS V5.1.3
WVS Language Support 5.1.3
Nuance 9.0:
Nuance Speech Server 5.0.2
Nuance Recognizer 9.0.3
RealSpeak 4.5.0
The documents might not contain this information as its a third party not supported version
Prashanth
Tinnakorn Mukud... Thu, 02/23/2012 - 21:12
I understand that it is not in the compatible list, but from the technical perspective the message information and format
should be in the document, so we can know how the thing works.
What if I have the same problem with Nuance?
(I was face the same problem with my local country Nuance partner in POC state and never found the solution)
Should I open TAC case for the problem that should be in the document?
What if our customer need the problem to be solved in 2 hours?
What if our customer would like to purchase UCCX with Nuance ASR and we fail in POC state?
I understand that even it is in the document may be I still facing the problem and in that case we then need TAC.
What I'm trying to say that some information like ASR should be well documented. So we can solved the problem faster.
Tinnakorn
