CAPWAP Primary/Secondary/Tertiary Question
Answered Question
After going to the High Availability Tab in the WLC GUI and setting the primary, secondary, and tertiary, how do you see that in the CLI in the AP?
I tried using show capwap ip config, it doesn't show any entries at all?
And also, is there a command to do that in the CLI in the AP?  to set the primary, secondary, and tertiary?
Thank you.
Correct Answer by Stephen Rodriguez about 4 years 11 months ago
sorry, missed the 'in the AP cli' part.
you can't set the information from the CLI on the AP, that has to be done on the WLC.
if you do a
show capwap client rcb
that shoudl show you what WLC the AP is configured for
Steve
Overall Rating: 5 (1 ratings)
Stephen Rodriguez Thu, 02/23/2012 - 09:20
you should be able ti see that with
Show ap config general
Steve
Scott Fella Thu, 02/23/2012 - 09:41
You can set the primary, secondary and or tertiary from the ap if the ap has not joined by doing:
capwap ap controller ip address wlc-mgmt-ip
If the AP's are joined to the WLC then issue:
config ap primary-base
show ap config general
% Invalid input detected at '^' marker.
config ap
Getting invalid commands for the both of them.  Below is IOS version the AP is on.
Cisco IOS Software, C1200 Software (C1200-K9W8-M), Version 12.4(21a)JHA, RELEASE SOFTWARE (fc3)
Scott Fella Thu, 02/23/2012 - 10:32
you need to run th config ap... from a WLC.  You have autonomous AP's so you need to convert them to LWAPP and you also need a WLC to do this.
"ou need to run th config ap... from a WLC.  You have autonomous AP's so  you need to convert them to LWAPP and you also need a WLC to do this."
It's been converted to LWAPP, but haven't joined a WLC yet.
What I wanted to do was configure a primary, secondary before joining it to a WLC.
Because what I would of done is first have it join a controller, then go into the GUI and change the HA (High Availablilty) and add the primary/secondary controllers.
Thought if I could skip the first step and try to configure it from the AP.
Correct Answer
Stephen Rodriguez Thu, 02/23/2012 - 10:37
if you do a
Steve
Leo Laohoo Thu, 02/23/2012 - 13:58
The command "sh ap config general " will give you the result in the end of page 1 and the top page of page 2.
Leo Laohoo Thu, 02/23/2012 - 15:19
is there a way to show the primary/secondary on the AP as oppose to the WLC?
No because the WAP does NOT keep these information.  The only "information" the WAP keeps is a simple stuff on WHERE the WLC is.  It's like ET-phone-home.
daviwatk Thu, 02/23/2012 - 20:31
Actually, the same "#show capwap client rcb" at the AP CLI that Steve suggested should reveal this information.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
