Bridging calls on same line button possible?
Answered Question
Feb 23rd, 2012
Hope there's a simple answer to this one!
On a 7970 phone, if two calls come in on the same line button, how is it possible to conference the two calls together?
If you're already on a call, it's easy to hit 'CONF' then dial the new number and bridge all parties.
Unfortunately when one call is on hold and you press conf on the live call, it immediately prompts to enter a new number, there is no way to select the other line that's on hold and add to a conference.
Thanks for any info!
Correct Answer by Mario Garcia about 5 years 2 months ago
Meet me must be enabled on the system and then you need to have the select and join softkeys in the hold state
Select both lines and hit join
Overall Rating: 5 (2 ratings)
mcasimirc63 Fri, 02/24/2012 - 20:27
  • Silver, 250 points or more
Make sure you have the "select" softkey under the "hold" call state.  Once both calls are on hold, push the select softkey under both lines, then hit join to bridge both calls.
Correct Answer
Mario Garcia Fri, 02/24/2012 - 23:38
NYCiscoTech_2 Mon, 02/27/2012 - 19:16
Marcus/Mario,
Enabling meet me on the system automatically enabled the select/join buttons using the default key profile.  Creating a new template with the hold state and join/select keys improved the user experience and ease of bridging.
Thanks again for the solution!
