Warning message
WLC 2504 and HP switch port settings
Feb 24th, 2012
I'm having some problems configuring a 2504 wlc and a couple of APs (1131) connected to a HP ProCurve switch. I would appreciate any input as I do not have any experience with HP ProCurve switches.
The WLC port1 are connected to HP switch with vlan1, vlan11 and vlan66 TAGGED (trunk).
Same vlans are tagged on AP ports connected to same HP switch.
Result: AP does not show in WLC
If I set UNTAGGED (access) instead, the APs shows in the WLC. The problem is that I need to use several vlans and ssid's
Interfaces:
mgmt -> HP switch
10.1.7.15
internal-vlan11 -> SSID: CONTOSO
10.1.11.2
guest-vlan66 -> SSID: CONTOSOGUEST
10.1.20.2
My question is, what's the correct setting on the HP switch?
Appreciate any help!
Stephen Rodriguez Fri, 02/24/2012 - 04:44
  • Purple, 4500 points or more
For the AP that access should be correct. If the ap is in local mode all the traffic will backhaul ti the WLC.
Steve
