iPad, unable to sync wireless.
Stephen Rodriguez Fri, 02/24/2012 - 05:05
Are the iPad and the iTunes on the same subnet?
Steve
thomas03usmcsf Fri, 02/24/2012 - 21:35
Do you have p2p enabled on the SSID?
thomas03usmcsf Sat, 02/25/2012 - 04:58
P2P is an option on the SSID configuration page under the advanced tab. Is it checked? What option is picked from the drop down menu?
Scott Fella Sun, 02/26/2012 - 11:11
You have Multicast enabled on the network side also?
Scott Fella Tue, 02/28/2012 - 07:40
I didn't either until I ran inot the same situation and enabling multicast on the network makes things work.  That is how I have to setup my clients when using Apple TV and that is how I have my home setup so I can sync my iPhone and iPad to iTunes.
