CIUS - How do you???
Answered Question
Feb 24th, 2012
  • Silver, 250 points or more
  • Community Spotlight Award,
    Best Publication, November 2015
Trying to do some things on CUCM 8.6.2a with CIUS tablets.  Can't find documentation on how to do the following things:
1.  While on a video call, how to you get the CIUS tablet to switch over and use the REAR camera on the call (i.e. how to switch between cameras while on a call)?
2.  How do you access things that would be controlled via softkey functions normally (like MeetMe)?
TIA
Cliff
Correct Answer by gnanem about 5 years 5 months ago
Switch camera when an active call is not possible. The following enhancement defect is opened:CSCtq23002    Support to switch between front and back cameras during active video call. And Meetme is not a supported feature on the CIUS. Pls refer the datasheet for supported feature for CIUS.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtq23002
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps7290/ps11156/data_sheet_c78-609507.html
Supports Docs:
http://www.cisco.com/en/US/partner/products/ps11156/tsd_products_support_general_information.html
Gnaneswaran.
-Pls rate helpful posts.
Overall Rating: 5 (2 ratings)
Correct Answer
gnanem Fri, 02/24/2012 - 10:23
  • Cisco Employee,
Supports Docs:
Gnaneswaran.
Clifford McGlamry Fri, 02/24/2012 - 10:45
Is there any way to have CIUS use the rear camera for a video call at all...even if it's for the entire call?
afmmanicke Fri, 02/24/2012 - 11:25
Maybe I'm thinking a little outside the box here, but you could set up a mirror on the front side of the CIUS and then, with the right angle, you could stand behind the CIUS and be visable on the front camera...
Clifford McGlamry Fri, 02/24/2012 - 11:40
Ok....you could do that.
1.  It's a cludge
2.  Suggesting that to a customer just sounds like a bad idea.
The reason customers want this is so that they can call someone and SHOW them something.  In a factory environment, that's not flying very well.
Clifford McGlamry Fri, 02/24/2012 - 10:49
That bug id isn't viewable by non Cisco employees.  Can you provide any summary of what it says/disposition?
gnanem Fri, 02/24/2012 - 11:08
  • Cisco Employee,
This Bug is raised for to Support  switch between front and back cameras during active video call and currently this feature is not supported.Hopes this will help.
Gnaneswaran.
-pls rate helpful posts.
Clifford McGlamry Fri, 02/24/2012 - 11:10
Understand.
Is there anything in there about when it might be available?
Gajanan Pande Mon, 04/09/2012 - 22:59
  • Cisco Employee,
As per the present plan, this issue will be fixed in CIUS firmware version 9.2.4. As of now Cisco had released 9.2.3 which is available here . You might want to watch out the space for 9.2.4 which will be released soon.
GP.
Pls rate helpful posts by clicking on stars below the post !!
Related Content
