WVC210 Remote viewing?
Feb 24th, 2012
Hi Everyone,
I just bought a WVC210 wireless IP PTZ camera and I am having a hell of a time trying to view it remotely.
For a router I have a Cradlepoint MBR-1200
I have read online to try and achieve this but no avail.
Any help is greatly appreciated.
Mike
Eric Moyers Fri, 02/24/2012 - 11:15
Hi, My name is Eric Moyers. I am a Network Support Engineer in the Cisco Small Business Support Center. Thank you for using the Cisco Community Post Forums.
In order to view the camera remotely there are a couple of things you need to do. Please see the document I have attached.
Eric Moyers
Cisco Network Support Engineer
SBSC Wireless and Surveillance SME
CCNA, CCNA-Wireless
1-866-606-1866
If this solves your issue, please mark this thread as answered.
tanningbedz Fri, 02/24/2012 - 12:14
Thanks for the instructions Eric,
I tried the instructions you provided but still no luck. Not sure what else to do?
Mike
Eric Moyers Fri, 02/24/2012 - 12:40
Probably Best and Faster to have you call in and let one of our answering agents work with you on this.
Let them know that you have already work with the document I provided.
Eric Moyers
CCNA, CCNA-Wireless
1-866-606-1866
Eric Moyers Wed, 03/07/2012 - 13:58
Hello Sir,
Just checking to see if you was able to get connected remotely?
Eric Moyers
ramiesw20 Thu, 04/05/2012 - 22:44
There are 3rd party softwares for spying that can solve this issue.
asarutanond Mon, 04/16/2012 - 16:37
Mike,
WVC210.
Log in to the camera:
1) In the "Setup> Basic Settings" change the network settings configuration to fixed IP.
2) You can use the IP that the DHCP previously gave you.
3) In the "setup> Advanced settings" change the HTTP port to 8000
4) Remember to save all the settings.
MBR-1200.
Just go to Virtual Server on your MBR-1200:
1) Name the application anything,
2) Input the camera's IP address (You should use static IP for the camera and not DHCP).
3) Protocol is TCP
4) Public port is 8000
5) Private port is 8000
Save it.
To connect to the camera you now have to add the port.
E.G http://192.168.1.5:8000
To connect from the internet you'll need to know your IP, just go to the browser and type whatismyip and you'll know what your public IP is. To connect to it from outside you just type http://71.68.241.3:8000 (example only)
Alan.
