Warning message
ASA STOP responding
Answered Question
Feb 24th, 2012
I have upgraded ASA5510 256MB to 1G RAM.
After one day of working, ASA stop responding.
I reload the ASA, but nothing came on.
The LEDs are
Power GREEN, Status AMBER, Active AMBER, VPN GREEN, Flash OFF.
Any suggestions
Correct Answer by Marvin Rhoads about 5 years 5 months ago
Status AMBER means you have not passed hardware diagnostics. I recommend you cycle power while connected via console and examine the power on self test output for additional information.
Opening the box back up and reseating the memory DIMM wouldn't hurt. You did use genuine Cisco memory and not a 3rd party, yes?
Overall Rating: 5 (1 ratings)
Correct Answer
Marvin Rhoads Sat, 02/25/2012 - 08:52
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 Firewalling, Network Management, VPN
boris.majstorovic Sun, 02/26/2012 - 05:22
I have already done it, more than ones and nothing.
But one more time, I thought it wouldn’t heart.
This time I disassembled everything it could be disassembled.
Clear everything and put it back.
Imagine - it works.
Thanks again
